I wouldn't say so, I did it without getting the wheel off.ThanksIs it a wheel off job?
The fuel filter is just in an awkward place, could do with jacking up the driver's side rear corner, and get enough space for you to get your arms and elbows in there! The clips on the filter are just little buggers.
Yeah once you've got yourself poking under the carEasy to do?
Looks good matey!
top job and SERIOUSLY clean![]()
A wee tip to remove the scratches on your dash is to heat them up with a hairdrier and rub on them really hard with a yellow duster, should remove all the little tufts of plastic that make the scratch really visible. Interior looks tidy.
Firstly can i say your car is looking spot on!
Secondly, I see you have a cupra spoiler - having difficulties fitting mine as i cant fit the brake light into it!
I cant slot it in from behind because the holes are not big enough and i cant detach the light from the wires because they are all one piece. Only way i can think of doing it, is to cut the wires and solder them back together once the light is in!
How did you do it?
Thanks in advance
Apparently the facelift Ibizas have a different light than the pre facelift and the cupra spoiler uses the pre facelift light![]()
interior is looking smart stezo![]()
Ah cheers mate, I didn't know thati'll have to give that a go
Thanks again
Cheers fellamuch appreciated
Actually I don't have a cupra spoiler, must stand out a bit if it looks that way
Not sure about fitting it but my mate jake (veyron) replaced his and didn't have to change anything afaik
