Picture time
Don't forget mate the engine was probably running hot by the time they managed to get the final map on. Stick it on the rollers at the next rolling road day and I'm sure you will see a bit more. Regardless of numbers that boost curve is bang on, one of the reasons I love my map done by the guys as its all usable with no stupid spikes
Thats pretty sweet DK bet your pleased with that! strange how the maps needed to be changed there :D
I need to get mine back down to AMD mine was running the forge tip with my result of 319.4lb/ft torque and AMD's stage 2 map + airbox
now running revo stage 2 and badger 5 tip with jetex cone so be interesting to see what happens with the setup now!
glad your happy! :D makes it more fun to drive deffo!
It's only running a little bit more torque than it was before but it now holds it longer :D
There will be a RR day at AmD sometime around Feb or March so keep your eye's open
Nice dipstick squire ;)
Text you about the results at AmD, but well done again mate. A1 service from them as usual I see :)
Cheers Tom :D
The car was flying today, nail the throttle and it will put you in the back of the seat like you'd expect, even on half throttle it is devastatingly quick :D hold it at 15ish PSI and it fly's with no effort :D
The exhaust and DV noise has increased aswell :D
I treated myself to some new detailing bit's over Christams,
3 weeks worth of dirt :whistle:
Snow foam lance from CleanYourCar.com
http://www.cleanyourcar.co.uk/washing-and-drying/snow-foam-lance-various-fittings/prod_371.html
Valet Pro - PH Neutral Snow Foam
http://www.cleanyourcar.co.uk/washi...ro-ph-neutral-snow-foam-1-litre/prod_516.html
I've not had a chance to try the other stuff out yet due to the poxy weather, hopefully I'll get to have another go tomorrow
Gtechniq - Glass Sealant Kit
http://http://www.cleanyourcar.co.uk/engine-and-exterior/gtechniq-glass-sealant-kit/prod_911.html
Valet Pro Dionysus Trim Glitz
http://www.elitecarcare.co.uk/valet-pro-dionysus-trim-glitz-500ml.php?manufacturers_id=52
Auto Finesse Citrus Power
http://www.polishedbliss.co.uk/acatalog/auto-finesse-citrus-power.html
The Snow Foam Lance is such a good piece of kit isn't it! I personally use Super Snow Foam with my lance, that gives a very effective covering, without stripping wax etc. I haven't seen the PH neutral product before, so I think I might give this ago next, as it seems to have very good write ups when referring to its strength in cutting through grime effectively; it looks like it got right to it in your pictures?
The car is looking tops as always Darren. Happy New Year!
James.
Nice purchases there Darren although you can't really call that dirt. I will bring my dirt bag down and then you can test this stuff ;)
Happy new year mate!
Mmmm a wet LCR :D
So you happy with the purchases then mate? Thinking of getting the lance sorted out next year and foaming up my LCR ;)
James.
Thanks James and happy new year mate :D
TBH I was'nt that impressed with the snow foam :(
There was about 3 weeks worth of dirt on the car, it was only spray from driving on wet greasy roads but the SF did'nt touch it, even after 2 coats it still did'nt even softern it, I ended up spraying it on the car and then going over a wash mit and shampoo, I spoke to Maz after and he suggested maybe spraying it with a pre wash cleaner like Auto Finesse Citrus Power which I've got.
Happy new year El :D
Mate by my standerds it was rottern :D
Mmmm a wet LCR :D
from everything I've read mate they are well worth having ;)
Still not had a chance to try my other new products due to the poxy weather [:@]
