Mine is an FR 2.0TDi - manual gearbox.
Sorry, my bad! Should have re-read the post!
has any one fitted the leds to a 5 door yet, if so which bulbs did you use? there seems to be a choice of 7w or 5w ones.....
Anyone one know which bulbs are the right ones for the 5dr? I thought these were, but they are huge! They fit into the bulb holder, but the glass bit just doesn't go through the hole in the cluster!That's not good...Were they the 5-door ones that Dan posted a link to? From the picture the bulbs don't look any bigger than a standard bulb.
You have to be careful.
The bulb part of an R10W is not much larger than the base. I've not taken mine apart so don't know how much larger the hole is than the bulb part of the standard lamp.
This one:-
http://www.ebay.co.uk/itm/2x-1156-Ba15s-Cree-Q5-High-Power-7W-LED-Reverse-Lights-/220819571615
- claims to be 20 mm diameter. I'm pretty sure that is bigger than an R10W but don't have one to hand to measure. Is this the one you bought CandyWight?
This one:-
http://www.ebay.co.uk/itm/CREE-Q5-P...arts_Vehicles_CarParts_SM&hash=item5198fa0112
- looks even bigger but I can't see a statement of the diameter.
Candywight's thread about her reverse light problem had this reply which seems to indicate success with a 5 door ibiza with CREE bulbs... Probably the car has a manual box, not DSG.
http://www.seatcupra.net/forums/showpost.php?p=3761879&postcount=3
