Reverse Light
BaldyDave
Mildly Deranged...
Aug 12, 2011
782
Central Belt Scotland
OK well I fitted the reverse LED bulb and nothing prepares you for just how much better this bulb is over the puny standard effort. The pictures posted on this thread were impressive, but nothing prepares you for just how much brighter the LED bulb is in real life! :-o
To paraphrase someone else on this forum, it appears as if the sun really does shine out of my Ibiza's arse now! lol
PS - the bulb operated fine in my car (no flashing reverse light) so it must be an issue with the DSG cars only.
IbizaTDI08
192
Sounds like another 'characteristic' of the Cupra. :(
I'm going to get round the issue buy taking a spur off from the light cluster and installing the standard bulb hidden inside the boot in a holder and then just have the LED fitted also. Hopefully this should cure the problem.
Would be interesting to see if any other cupra does it.
CandyWight
1.2tsi 5dr Ibiza Sport
Jun 23, 2011
290
Isle of Wight
has any one fitted the leds to a 5 door yet, if so which bulbs did you use? there seems to be a choice of 7w or 5w ones.....
I bought these from ebay and when I tried to fit them, the bulb is too large to fit through the casing in the lens so you can't fit it all back together again! [:@] Anyone one know which bulbs are the right ones for the 5dr? I thought these were, but they are huge! They fit into the bulb holder, but the glass bit just doesn't go through the hole in the cluster!
CandyWight
Jun 23, 2011
290
Isle of Wight
That's not good... :( Were they the 5-door ones that Dan posted a link to? From the picture the bulbs don't look any bigger than a standard bulb.
Doh, I forgot to post the link! Yes, they were the ones that I was told about earlier in the thread - but I bought ones that specifically stated Ibiza in the title. Here is the link http://www.ebay.co.uk/itm/350458872082 - they are huge chunky things - I think the bulb circumference is bigger as the casing wouldn't go back on over it. Unless it's me having a girly moment, but when I put the original bulb back in everything went back together straight away.
Feb 8, 2011
743
You have to be careful.
The bulb part of an R10W is not much larger than the base. I've not taken mine apart so don't know how much larger the hole is than the bulb part of the standard lamp.
This one:-
http://www.ebay.co.uk/itm/2x-1156-Ba15s-Cree-Q5-High-Power-7W-LED-Reverse-Lights-/220819571615
- claims to be 20 mm diameter. I'm pretty sure that is bigger than an R10W but don't have one to hand to measure. Is this the one you bought CandyWight?
This one:-
http://www.ebay.co.uk/itm/CREE-Q5-P...arts_Vehicles_CarParts_SM&hash=item5198fa0112
- looks even bigger but I can't see a statement of the diameter.
CandyWight
Jun 23, 2011
290
Isle of Wight
This one:-
This one:-
That is the one I bought - just measured it and it's 14mm diameter. It just doesn't fit through the hole in the casing so you can't put everything back together. Gonna have to send them back as they are not worth keeping at that price if I can't even use them! Maybe the ones in that first link you gave me would be better. So disappointed as I was looking forward to having some visibility behind when parking on my drive tonight!
CandyWight
Jun 23, 2011
290
Isle of Wight
I'm not sure - it wasn't going through the hole and I wasn't about to force it! I don't have the tools for cutting the cluster, unfortunately. I thought maybe it was me not being confident enough to get the cluster and lens back together, but as soon as I put the original bulb back in it went together so easily, so I know that the bulb just isn't gonna fit in there! Still, I am encouraged by the fact that I managed to dismantle it and reassemble without any help from a man, lol!! I think I may dismantle it again and measure the bulb that is in there just to make sure I get the right size next time!
Shelby
93
West London
sorry, to clarify, has anyone on here who has bought that CREE LED off Ebay got a DSG and not had any strobing problems?! I have the 1.2 Tsi DSG and was about to buy the bulb when i noticed the strobing problem mentioned earlier. Not wanting to part cash until this is verified!!
cheers
Deleted member 67732
bulb diamensions
the diamensions of the 245 reverse bulb are 19mm wide these are fitted to my 2010 5 door ibiza
type 245 into the consumabulbs website for diagram
Trotski
259
Darkest Shropshire
Candywight's thread about her reverse light problem had this reply which seems to indicate success with a 5 door ibiza with CREE bulbs... Probably the car has a manual box, not DSG.
http://www.seatcupra.net/forums/showpost.php?p=3761879&postcount=3
seen that, but the seller seem to be on holiday, (Has everyone bought bloody the things!;) )
The DSG problem isn't too much of a worry, 1.6 tdi st, but was trying to see if 5w was good enough, but now there seems to be a small hitch with the diameter.....
...but thanks for the heads up :thumbup:
