If the pulses are dampened at the crank end, they are dampened throughout the engine.
I have a very aggressive mapping, which is rated for Stage 0 and 232 lb-ft, but took great advantage of intake, IC and exhaust mods to run 264-265 lb-ft slightly above 3500 rpm. AUQ engine (different rods compared to an AMK or BAM). Map installed at 30k kms, now 86k kms and still runs strong. Engine had been opened at 70k for
repairs due to a sheared cam belt and also changed the piston rings - all 4 rods were in good shape and straight. Car had been driven hard, plenty of full throttle from 2000 to 5000 rpms and 1.5 bar of boost. Still on stock DMF.
After some horror stories which reared their head in 2010 and 2011 here and on Audi TT forums, I've bitten the bullet and invested in a Fluidampr to give more dampening of internal shocks and protect 2 things I'm scared for: the rods and the timing gear. The way Fluidampr runs (counterweight oscillating in a fluid filled space)
is very similar to a second DMF at the opposite end of the engine.
I also avoid like plague any form of thrashing the engine before it had hit full operating temperature, leave it running a bit at idle before shutting down, change the oil at precisely 10k kms, only with the best juice on the market,
and avoid detonation like plague and AIDS together. Detonation kills. Use only the best fuels and do all mods to get cooler running cylinder heads. There were some hapless guys with AUQs and AGUs in MK4 Golfs who got melted holes in the pistons due to detonation, and what is worse,
the engine is so balanced that unless you follow the slightest change in running, the destruction of the rod or piston can go unnoticed for a long time. Truly nightmare fuel.
Maybe I was lucky. Only God knows what may happen in the future.
~Nautilus
