The must be a reason why i appear to be the only one to get this every 2 days
cel light
I get it every couple of days lol it clears itself, comes back a couple days later, and round and round we go lop
Hi,
Just done and my ibiza fr has lost all boost, basically its gone into limp mode.. I havnt got a boost gauge so do i only have to put the 1 vac line from the dv to the inlet manifold?
Danny
The 2 vac lines on top Right of the intake manifold go to
- FPR
- Diverter
Is this how yours is connected? Can you take a photo?
Can't at the minute.. Yeah I've got 2 vac lines on the inlet but I've got rid of all that crap on top so I've run the new vac line from the dv to the inlet..
i havnt got the boost gauge so no t piece
-tried to upload a photo with markups, can't as I only have 4 posts-
if you remove the spaces from the following and post with the image tags, its the image
http://i616.photobucket.com/albums/tt241/nooneGTI/2vaclines.png
Yeah mine looks the same but I'm still have boost issues, its constantly going in and out, it was doing this before the bypass anyway, maybe a boost leak somewhere.
Heres mine anyway
Should I put some sort of clip around the blue vac pipe to stop it coming off or will it be ok like that?
Cable ties work fine at both ends of the vac lines.
You don't have any resistors in your plugs?
vac line routing looks fine.
If you already had boost issues, I don't think that this is the issue for the boost. check all your vac lines for a break, scan your car, may show you whats happening.
Yeah I've added he resistors but still having the same issues..
Where does everyone put the plugs once the resistors are in, mine are just sitting on top of the engine and.get pretty hot!
I still get it to date every couple days. Keep a vagcom in the car to clear it when it comes on
ive got a similiar boost issue, valves bypassed, SAI bypassed, been stage 2 mapped by big fish tuning and SAI mapped out, what i get is 1.5bar boost peak then drops to a bar then up to 1.4 then down to 1 bar then by around 5000rpm it will hold about 0.7bar which is a total pain!! it should peak around 1.5 and hold around 1.2bar to redline! any ideas? boost leak, MAF etc??
car is off the road for winter but im wanting to sort this issue before its back on the road in april!
Thanks.
