Thanks a lot mate! I was thinking about this kind of hole saw but I feared it wouldnt take cutting metal very well. Good to know it does :)
Also I was thinking about 1 hole vs 2 holes as you suggested and I guess it will just come down to how much place is there around. My beeza is LHD so I wont be able to run the cables exactly where you have cuz it would be very close to my gas pedal. I'll have to run them through the bulkhead in the middle directly under where the additional gauges are. Kinda hoping it wont be a problem
Having them going out more central will be a better idea i think
Looking to change mine more central soon as my gears are quite annoying at times, think its the way the cables are routed on mine, kinda forced into positions where they run into the passenger footwell, not ideal
That's pretty good to know too, thanks! Although I have to admit it got me a little scared now to do this upgrade at the same time with doing that "DIY short-shifter" which I'm sure you have seen around on these forums. Might be a better idea to go step by step checking out how the gears work first and then moving on to making the short shifter. Wouldnt really like to end up with having the gear shifter raised and supposingly shorter throws but unable to select gears. I wanted to do these upgrades at the same time while I'm building a new engine and the car is pulled apart
Yesterday i fitted my new poly rear top mounts, nice easy 30 min job
Randomly when refitting the rear wheels, all bolts went all the way in fine by hand but then when it came to tightening 2 of the bolts kept turning and knackered the threads on on one of the hubs :(
Have no idea how it happened as the bolts went in fine, definately didnt cross thread, but new rear hub and wheel bolts hopefully tomorrow
Also rerouted the gear cables in a new hole, much better :D
Few pics of the problems
the hub, 2 threads are like this
On removing the rear brake discs, was shocked at the condition of the inside of them
Now sits awaiting its new hub
Ha well spotted. Its going on the 306 lol well hopefully anyway
Yer ive replaced one hub a few years ago now
Hopefully all sorted this evening :)
Sent from my Galaxy Note using Tapatalk 2
Yer its a ball ache tbh lol
Got the hub on and brakes sorted on 1 side
Other side the carrier bolts are being a pain so will attack those at the weekend now
Cheers to Chambers for the parts as always!
How the engine currently stands
Have a rocker cover to get powdercoated along with the inlet and strut brace and a few other little bits :)
Yer it does turn some heads lol ill have to get some vids up they turned out quite good
Bit of an update
Ordered my Peloquin LSD with Alex at AKS yeasterday afternoon, he predicts possibly around a week till it arrives, cant wait :D
Few other little bits i have
3"decat
Lamba spacer
New weld on lambda boss to use my wideband on the decat
And these....
Short shift kit and a Richbrook gear knob
Steering wheel spacer
