hi Sam, its one of the earliest hybrids made but she boosts well.Awesome result Carlwhat spec is your hybrid? I'm now running the relentless hybrid.
She does indeed thanks, the manifold made a decent gain but its the wmi which made the biggest difference... so smooth. WMI is off most peoples radar but personally i think its one of my most important upgrades.Good numbers there, bet it pulls like a train
Hi Mate, have a look here as Craig the owner of GOTBOOST explains what some setups can expect off his rollers:-Good results Willy
a few questions though, as always!
The trans losses seem unusually high, 253 at the wheels, and 325 at the flywheel? mine recorded 254 at the wheels yet just 291 at the crank on the conservative map it was on previously, so much, much lower losses. I wonder if that's a true figure or if the losses are just exagerated?
Also, the speed at peak bhp looks very low, around 90mph at about 6k revs, isn't that 3rd gear? or 4th? I thought 1:1 was closer to 5th gear on a 6 speed. Could that explain the higher trans losses shown? or the huge torque as can often happen when dyno'd in a low gear?
Certainly looks like a riot though, holding 21psi at 7000rpmGood to see the hybrid route is still working out for some people!
Can't wait to get mine back on the road and mapped again![]()
She does indeed thanks, the manifold made a decent gain but its the wmi which made the biggest difference... so smooth. WMI is off most peoples radar but personally i think its one of my most important upgrades.![]()
hi mate, i run a Devils Own voltage referrenced controller which i'm currently using the map sensor to trigger the system. I use a DO3 nozzle which is approximately 250ml / min although i' soon be running the equivalent of a D04.Hi there
In the middle of sorting out the K04 hybrid set up on my LCR (its been a long drawn out process so far!) and had a couple of q's about your WMI.
What system are you running? Also what size nozzle did you go for? And what mix of meth / water do you run?
I have got an AEM system and thinking of going for the middle nozzle out of the 3 sizes they do? And running a 50:50 mix?
Nice figures btw - would be happy if i get the same![]()
.Clutch options will most probably be my next big purchace.
lolVerrrrrrrrrrrrrry nice set of upgrades there. Shame about the lack of pics on this thread thoughlol
Last Friday i Had the following installed at TSR Performance. She feels like a different animal now.
Quaife LSD
Sachs performance clutch
Bilstein B12 shocks and springs with new top mounts.
Superpro wishbone bushes
Neuspeed 25mm front arb
Neuspeed 28mm rear arb
Falken 453 front tyres.
The weather is poor at the moment but hoping to stretch her legs a bit more when it improves.
i need to get the tune in excess of 350 bhp and it feel like i'm enroute..... 265g/sec at the moment in a scaled stock maff tube.
its a 15/20 kit. i have no intention of tracking it. If i was i'd go hardcore coillies like clubsport.That's a very similar set up to what I've got planned, I'm glad it all works well together. Did you go for the 15/20 or 40/20 kit? I'm thinking of going B14 but I'm still undecided where to fit coilovers or not.
