You need AB for the dim with dipped and EF for the dim with indicators. 2 and 3 as per the gti instructions for left and right.
I've got it working now!
I settled for 80% on Dipped and Sides & 70% on for Indication (this looked ok at night but need to check in daylight as could be too bright and needs readjustment)
Thanks for your quick response Dean, your explanation is much better as the gti forum just referred to CD option as 'Parking Lights' which I thought was the dipped lights but on my Leon the value for It was already set to100 so I thought the instructions were wrong. So It seems for us Leon owners this setting refers to our DRL only.
So to make it easier for anybody else thinking of changing the DRL brightness I have summarised it below:
- Go into [09] Central Electronics
- Go to Secuity Access and enter 31347
- Go into Adaptation
- Then change the channels as follows:
To adjust DRL brightness when Dipped and Side lights are on - default value = 35
LHS - "(6)-Leuchte2SL VLB-10-Dimmwert AB2"
RHS - "(6)-Leuchte3SL VRB-21-Dimmwert AB3"
To adjust DRL brightness - default value = 100
LHS - "(10)-Leuchte2SL VLB-10-Dimmwert CD2"
RHS - "(10)-Leuchte3SL VRB-21-Dimmwert CD3"
To adjust DRL brightness for when Indicators are on - default value = 35
LHS - "(14)-Leuchte2SL VLB-10-Dimmwert EF"
RHS - "(14)-Leuchte3SL VRB-21-Dimmwert EF3"
