Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
I tried to use that golfgti forum instructions but the options are totally different from what I can see. Dean or Anybody else that have successfully implemented this mod, could you please provide the link to the instructions you used?
Many thanks!![]()
You need AB for the dim with dipped and EF for the dim with indicators. 2 and 3 as per the gti instructions for left and right.
Hi
There are coding differences between mine (early car) and AJ's (newer car)
This could be to do with other tweaks AJ has made, however I've done a spreadsheet to compare coding of 09 & 52 areas which relate to the wing mirror issues, as mine and AJ's have different features, I don't have issues with it returning, but he can adjust his lower and it will return while mine won't.
Hopefully someone more familiar with coding can assist.
Thanks AJ,
I wondered whether some different parts/serial number was down to the build date of the car rather than anything else, though if there are chips relating to function then an updated part may be the answer.
Someone on Briskoda hinted that memory seats are needed to store the mirror position but I don't think thats right, I never had them on my Golf and it still save the mirror memory.
Hi all, I'm new to VCDs but got everything connected up. How ever, I'm a bit stumped. E.g I was trying to put the laptimer on but it says select STG 17. When I select anything with 17 on it, that refers to instrument and can't find anything related to a timer. Any help would be appreciated. Cheers
What would you guys think about this: http://youtu.be/60rbi-EQt8g
Yep agree I'm not a fan of that either, just looks a bit odd to me
I was a little disappointed that the indicators on the Leon uses bulbs rather than an LED strip like on the Mk7 Golf and new A3, that would have finished the car off nicely IMO.
Evening everyone, activated the needle sweep, locking chirp and carbon display tonight which I was delighted with. However, the first time I go to start the car up with the cable in (it's happened twice) it ticks over about 2-3 times before the engine actually starts. This has never happened before. Should I be concerned? Has this happened to anyone else? Cheers all!
Our front indicators are LED?
