TBH the best coding would be 0 =drl with rears, sidelights = drls off, & on. Reckon that might cause mot issues though.
  • Alarm chirp on lock/unlock not happening.
  • The blinker cycle adjust not happening either, takes the change but indicators still only flash three times.
Any pointers to error of my ways feel free :)
To be fair I'm not getting long enough to browse VCDS with the laptop battery life, might be worth my while rolling out the extension lead to the bottom of the garden for mains power.
Whay kind of VAG cable and which version of VCDS are you using?
Are you using the cracked version or the original version of the VCDS program?
What is the production date of your car?
I asked so many questions :) but I try to do conclusion.
For example my 140 FR is a 15 th of November production car. I did alarm chip but I could not do blinker cycle and rain closing.
Alarm chirp was there all the time, didnt realise I had to go into the MFD to enable it :think:
Blinker adjust doesn't appear to be an option for me....no big deal
Hello Metomurti,
1. in blinker cycle you must do some mistake, because on all models this option can be accesible and changeable,
2. rain closing - not possible to change in VCDS 12.12.0, but in VPS (other kind of software and cable)
I'll revisit it kopnyr, cant recall the message but it was something definitive like 'Not Available'.
Thanks for the heads up ;)
Sorry Andy,
for good understanding,
do you have "no available" step in blinker cycle ?
Sometimes you must set ignition off for 10 mins and then on, and of course restart the VCDS.
Sorry Andy,
I cant recall offhand kopnyr but I'll revisit the thread with a more comprehensive report the next time I have VCDS hooked up ;)
At last I changed the blinker cycle. After changing it 3 to 5, I turned the settings of only lights section to factory settings. Then everything is OK :)
Hi, I have got the VAG 12.12 cable and CD from ALiexpress. I have downloaded the CD to my laptop but when i plug the cable in it comes up with driver not found and unable to install. Any suggestions to what I'm doing wrong? I am using windows 7.
1) Uninstall the cracked software that come from aliexpress.
2) Download original software from rosstech. Version is not important.
3) Install original software.
4) Uninstall original software.
5) Install cracked software that comes from aliexpress.
So driver problem will be solved then.
Seems like a common issue with Windows 7 whereby the driver is not found after software installation, I had this issue too. You could try manually installing the driver by pointing the device to the installed VCDS folder.
Here is a link to a Ross Tech video to help with installation issues, go to around 7 mins and it talks about driver issues within Device Manager:
Video Link
In the end to get around my issue, I just ran VCDS within a virtual XP machine :)
Thanks that worked :)
