Fitted my brembos and ds2500s yesterday (will be going out tonight to bed them in) and machine polished the car today to get rid of as much swirling as I can. Even got my very own 50/50 shot which I'm quite happy about. Just polish dust on the left.
Such a good job I can't even tell what colour your motor is! Tis a mirror, cracking work. :)
Sent from my HTC One X using Tapatalk
Fitted 3" Turbo-back cobra exhaust, decat, non res. Had a stage 2 map.. safe 282bhp/296lbft that day on that dyno, etc. Sounds epic.
Took Leon in for its MOT, and passed first time :D not bad for a 10 year old car !
Sent from my Nexus 5 using Tapatalk
Took Blackie in for a 120K full service and full cambelt kit change.
Also had to replace the crank shaft sensor which was causing issues with problematic starting.
Car is now running sweet and pulling hard!!
Fitted a new CD player, carbon fibre wrapped th climate control and CD player surround looks a lot better now. Ordered 5 meters of blue vacuum hose to replace all hoses and started to make my drivers heater vent into a boost gauge pod, will keep me busy for a week or so, I'm after a new gear knob ,gaiter and surround but th surround has to be black anyone selling one?
Had a badger 5 v2.2 tip fitted. Mid range feels alot better. Had a creation motorsport tip before. Well impressed with the v2.2. More torque is always great
Replaced both front wishbones because the old bushes were shagged....nice and tight again now!
Did you get the tracking done afterwards
I've gotta do mine this weekend today as well as the driveshaft replacement so I can do the CV joint so I'll keep the standard driveshaft tucked away in case I have any problems. I was wondering whether it'd send the alignment miles out is why I asked :)
Also hopefully later on today I'm going to take the car to be plugged into VAG-COM and hopefully get the new CCM programmed in so some the features may work :D
Yeah alignment is a must after replacing the wishbones, i just got a garage to do it, bought 2 brand new wishbones with bushes and balljoints for £35, £40 for fitting and tracking.
CCM programming takes minutes, managed to get one for £8 since my remote central locking was fudged on my old one.
I knew that the alignment needs doing but as me / brother are planning on getting it done today but the garage is likely to be shut by the time we got it done but I'm going to need the car to get the CCM programmed in obviously that's why I asked lol, I'll get the tracking done Monday I expect providing it's able to be driven :)
I've stayed OEM with it, I'm trying to get it to be sorted properly before I start tinkering, The only mods so far on it are a set of the later spec Starfish alloys / debadged it but that's it thus far lol
Today we've replaced the driveshaft and the wishbone as hoped and it tracks better than it did before although I'm not surprised considering the state of the wishbone bush :(
I've also discovered I need a few parts for the MOT in 3 weeks too though :(
Fixed the rear door seals with the usual leaks (been needing done for a while now lol). Also given a look over underneath and decided its time to change the track rod ends and ball joints. Then last but not least I cleaned it inside and out.
Had it valeted and am now pricing up a front mount intercooler! Although I am also looking at maybe selling and getting a zafira vxr
Sent from my HTC One_M8 using Tapatalk
