Ronin225
4,652
22
Worcester
Bedford GT circuit, just standard diff.
Couldn't get any videos as they don't allow suction cup cameras and my rear brace is too low to see out of the car. my friends got some photos though
Mrlewell
17
Buffed the scrape out of my bumper!!! that some ***** left for me at the weekend,only had my LCR two weeks
DannyJigg
237
Southend, Essex
Did the below yesterday acternoon but was working a night so it's still "today" to me.
Ripped the under cat heatshield off as it was bent and only held on by 1 bolt and some rust. Hoped this would cure an annoying rattle when pulling away but it's only lessened it. Suspect either the top heatshield has worked loose or a silencer is shagged - need to get under it again. While doing this found that my exhaust has been repaired (somewhat roughly) in the past. That may be part of the problem.
Took the SAI pump off to repair a failed rivet but haven't got any rivets/bolts long enough so it's staying off til I get a chance to buy some.
Currently trying to decide between fitting my 1.9d centre pipe a bit later today or leaving it for another day...
Jimmy3rown
49
Hampshire
I wrapped the rear badge/handle!
Semideum
Portsmouth
Had my windscreen finally fixed after weeks of arranging it. Now onto fixing the boot as the latch is jammed and to get the radio out of SAFE mode. Do not have the original number sadly =( god damn second hand cars.
Redrevis
50
7
Derbyshire
Had a new cambelt and waterpump fitted today, along with a rolling road session at JBS in Chesterfield. Pushing out 191BHP so not too bad. Would post the dyno graph but still can't post pics yet :whistle:
DannyJigg
237
Southend, Essex
Love the wrapped rear badge, subtle but classy.
I bit the bullet yesterday and fitted the tdi centre pipe. Not a massive difference to the sound but it seems to let the turbo spool around 500rpm quicker than it used to. The mounts were in the wrong place but some fettling made it fit ;)
Word of warning, cutting the old pipe out using just jack stands and grinder sucked! Started raining halfway through as well, I love the great British weather :)
Feel a lot better about my abilities now i've done it so it was a win/win job
RaviR50
2,756
Southampton
soo yeah ;)
one of the spacers was broken when i took the old set off so i need to get a new 10mm then im think a 15/20mm on the rear. front sit flush with the 10mm rears will poke nicely with the 15/20
next up before players is to get the adjusters out wind the fronts down a bit and if i can get some i want some camber shims for the rear :)
Aug 27, 2012
581
Maidstone, Kent
Not really done anything to my Leon today but did do some work on the Audi Quattro removing the floor ready for my 4wd conversion :) Pictures can be found on my readers ride linked in the sig
nd-photo.nl
4,429
503
The Netherlands
youtube.com
Replaced the injector seals with fresh new ones.
Old:
Dirty injectors 1+2 by ND-Photo.nl, on Flickr
Dirty injectors 3+4 by ND-Photo.nl, on Flickr
The cups should be grey of color :) The cups are fine and dont need replacement yet.
Injector cup 1 by ND-Photo.nl, on Flickr
Injector cup 2 by ND-Photo.nl, on Flickr
Injector cup 3 by ND-Photo.nl, on Flickr
Injector cup 4 by ND-Photo.nl, on Flickr
Time for cleaning the injectors. They were pretty clean though.
Dirty injector by ND-Photo.nl, on Flickr
Dirty injector closeup by ND-Photo.nl, on Flickr
The old seals looked fine, but were far more stretchy then the new ones. Old ones top, new ones in the bottom of the picture.
Old (top) vs New (bottom) by ND-Photo.nl, on Flickr
Back in place by ND-Photo.nl, on Flickr
The Swede
Viking
Nov 23, 2013
94
North of the wall
Cured my hangover and headache by dropping in a Green Cotton panel filter in which made it much more responsive.
...and then got a new headache from discovering rust emerging from under the black plastic trim on one of the rear doors. Scheisse...
