rob929
252
plymouth
Went on rolling road. 267.4 hp and 328 ft/ibs torque. Not bad for stage 2 map without fmic. Was told the map was excellent so thumbs up for revo map.:D
SLCR
Just had my FR lowered on Eibach Sportlines. However, I've noticed that the drivers side is sitting lower than the passenger side! Any ideas what's causing this? Just hoping it's gonna settle
SLCR
Lol! I ain't that fat! I hope it does! Can't think why else it would be sitting the way it is
Oct 15, 2013
926
Midhurst, West Sussex
Today I took it to a garage to get the track rod end / tracking done as me and a friend couldn't remove it with brute force or ignorance.
New one's on it and it's got 2 days before it's MOT
I'm hoping it won't fail on too much because if it does it's toast :)
bruceR
2,577
665
Monifieth, Dundee
Have you checked the tyre pressures???
I had my 2nd set fitted a couple months ago and as said they take about a week to settle properly ;)
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Nothing, zero, zilch :(
I need to make a heat shield, fit the TIP, replace the exhaust, fix the tracking and sort out the front spoiler....anybody have a 36 hour day clock ?
stupot_1982
270
Filter
Thought I was finally get the Pipercross filter and adapter on replacing the Ramair filter I had. Seems a better pull lower down. Was getting roughly 200 g/s at top end.
Realised the TIP inside was full of oil, (think thats normal) so I took that off and gave it a clean. Also trimmed the inlets on it a bit for a better fit. Thought I would check the turbo compressor wheel, looks good to me.
gave a Nissan 300zx a shafting while testing ;)
