Is ther a functional video of which I can copy to install this camera
@Zayynn12,
The video not show the procedure but showed only the Bruno's car!
Is not hard to remove the cd/mmi And to install the video cable is easy.. Only one time to remove tge plastic around the front and rear door.
My car came with rear parking sensors only and no park pilot button or camera. Is it possible to retrofit aftermarket front sensors and have them appear in the screen like yours? The OEM ones cost around $300 which is insane for a couple basic ultrasonic sensors. Thank you for your time.
Wondering if you got round to making a video :)
Also did you get a lamp error when starting the car
I've installed on mine and i'm getting a lamp error on mine. I'm still trying to find someone with vcds/obdeleven do activate the cam (i've a vcds cable but it's outdated for our car....)
Look my thread about odb eleven encodings and make the two codes, one for the rear lamp and one for the rear camera.
Your topic is bookmarked on my browser since it's creation, it was a great contribution :D
Now waiting for my obdeleven interface to arrive, i'll miss vcds but the one that works on our car it's just too expensive
I'm too lazy to go to the car to take a picture, but it is visible here: https://www.autocar.co.uk/sites/aut...ves/legacy/ibiza-exclu-1350.jpg?itok=sE3oztV8 (the small black thingy above the registration table).
The quality is average... it's certainly very useful and I'm glad to have it, but I wouldn't be surprised if an aftermarket camera gets better image.
Hi, if you have the camera, can you check if you'd see the number plate at the bottom curve? I wonder if my coding changed the view. Thanks,
@Bruno Maia ,
hi , according you is possible to activate the rear camera during the driving?
According you is possible to activate some bit in obd to come out in our radio cdb one button to turn on and off the rear camera?
see you
@Bruno Maia,
i received the rear camera !!!
:help:
These my wires that i received:
1)
This wire seems too short to bypass from the bumper to arrive near the rear right stop/light...
2)
This filter need for what?
Is required or i could connect directly without this filter the two power wires from the rear light in the connector :
wire positive-->black and blue
wire negative -->green and Blue
3)
This connectors, one for the rear camera one for the radio connector but the two red wires?
i leave it to your selves?
Ok the modding rear camera is been made!
No filter need!
@Ghost45 the fisheye lens of the camera makes the number plate appear as a curve at the bottom of the screen.
