Not sure if it’s the brake servo or the turbo actuator line
I think with the Cupra R if you convert all grills to honeycomb it looks the tits!I found it strange when i got my Cupra i noticed that the LCR's have a different grill pattern. Whats with that? Im not sure what I prefer, possibly the honeycomb but im biased lol.
While we're on the topic of Grills, does anyone have any recommendations for what to paint the grill plastic with? Mine up close needs a touch up as its got some kind of overspray or something on it.
I'll get a better look tomorrow. If it's anything to do with the brakes, would it have something to do with why I've been getting inconsistent pedal feel for a while?
It’s nothing todo with the brakes it was me getting the two post mixed up yours was the post that I said to tie that pipe up so it stopped rubbing and the one I thought it was on a 1.6 Leon with a pipe all taped up that looked from the picture he posted was the servo pipe my bad sorry
I would just replace that pipe with some silicon hose and make sure it’s not rubbing on any thing
No problem! The new hose is on its way, so one way or another, this'll get sorted. Vacuum hose is something that's totally new to me, so it's got me a little freaked out, which probably comes across in my posts!
I was only trying to get the car through emissions and here I am cleaning the EGR, the inlet manifold is coming out today and now I'm talking about replacing vacuum hose.
It's mad how quickly this stuff spirals out of control...
TastyAbout 3 weeks ago I took a trip to corbeau to order my new seat.... this morning I received some pictures of said seat... It's being posted out later today.. in just wanna sit in it View attachment 12969 View attachment 12970
Well, that's a first. After a spirited run to work I got just round the corner and off popped the coolant reservoir cap. And lots of steam.
My complexion is lovely after opening the bonnet for a look.
The front driveshaft came loose while driving!?!!!! Hahah so will be fixing that next week![]()
Sent from my RMX1993 using Tapatalk
Luckily i heard a slight tapping and i felt it through the Floor board and thought that's not good, pulled into the next neighborhood and at 5 miles an hour it came completely off and was clacking like a mofo and I knew what the Problem was before even lookingHoly shitballs. That could have been so much worse.
This makes me incredibly paranoid about every noise my car makes hahaLuckily i heard a slight tapping and i felt it through the Floor board and thought that's not good, pulled into the next neighborhood and at 5 miles an hour it came completely off and was clacking like a mofo and I knew what the Problem was before even lookingdefinitely could've been worse
Is it a Diesel? I forget...Ran the car for a while today to see where the leak was coming from. The smoke cleared as I expected, but when I took it on the road, when I put my foot down, there was no real acceleratio. Luckily though it doesn't seem to be coming from the intercooler pipe and more from around the EGR valve - it actually seemed to spit a bit of water out of the top, which could be left over from when I cleaned it.
Next week I'll have a feel around and tighten all the bolts and make sure the gaskets are where they should be and hope that fixes it. If not, I might just admit defeat and take it to the garage. I've had a job come through today which means i can afford to get the clutch done, so I might combine the two.
