Same here, would like to delete it entirely. ABS dont bother me muchIt's part of my start up procedure...
Engine on, seat belt on, traction control off!
Sent from my SM-A405FN using Tapatalk
Checked your brake fluid?
Religiously!
It's stayed exactly the same. Checked all the brake lines and had a garage do it as well and there's nothing leaking, nothing bulging.
I mean, as long as they get through the MoT they're obviously safe, but it's just weird.
Only if there is play in a wheel bearing. The wheel will tip in slightly at the top under the weight of the car. Although,if there is play, you wont be able to see it. Will have to jack up each corner and check for play.
If theres play, itll be tilting the disc slightly aswell, ever so slightly pushing the pads back away from the disc.
Could be the problem. Worth a check.
The more I Google, the more my symptoms come back as wheel bearings.
Looking at my paperwork, the only wheel bearing I've ever had replaced is the nearside front - and it was a fleet car with 80k on the clock when I first got it.
When I moved the car today, I drove with my window open, and I heard a sound that I thought was either a caliper dragging or a wheel bearing.
Does any of what I'm saying sound possible?
Dude if it passes the mot and they work let it goI feel for you
Spent the afternoon making brackets and bits to hold the oil cooler and what's going to be the power steering cooler..... then forgot to take photos... came home and just had a quick mock build of the dash....
I've learnt a lot about my car doing this, but I've also learnt a lot more about myself - I'm a stubborn, stubborn arsehole who does not, cannot and will not admit defeat. I'm not sure I'll be able to stop - poor choice of words when it comes to brakes - until they're perfect. I can't deny I can get a little obsessive.
In other news, my homemade press did this today... It makes life much easier once you know it can be done... Now at least I'll be occupied with my bushes rather than obsessed with my brakes.
Ap 6 pot calipers. 2 piece 368mm discs. With XXR 18 x 9.75 wheels with BTCC tyres. They should stop it
Personally Manic has it all wrong with his brake setup...you next as light as possible for less weight.
