iammooks
1,739
1,131
Getting it clean to say goodbye tomorrow
Sent from my M2007J20CG using Tapatalk
I have a love/hate relationship with mine, but there's an attachment there. At some point in the future I'll be moving to France with my girlfriend, and even now I feel sad at the prospect of selling it.
Hope it's not something you'll come to regret.
supersticky
1,014
46
taunton somerset
I've had 5 mk1's. 1 180auq and 4 pd150's I'm still fluffy about them...love them but they are getting on now, traded it for a Exeo st sport.
I will still be flashing any mk1's that pass
Rich.T
1,609
932
I like the Exeo.
I went off of them when i did a cambelt on one (twas a sh!tter though).
Im not a mechanic anymore so if i had one id be getting someone else to do the job instead.
I like em again now lol.
Good luck with it.
Stick some pix up when you get it 👍
Rich.T
1,609
932
So, decided a few weeks back to go vent to atmosphere with my catch tank.
Ordered the hose from Ebay and it turned up soon after. Left feedback and got on with my life.
Also ordered an ally bung to cap off the hole in the tip.
Just opened the bag that the hose came in and its got splits in it!
Not all the way through but if you twist it you can see cords.
Im going to use it now as i want to fit it tomorrow and it basically attaches to the outlet and drops down to just below the subframe.
Note to all, if you buy something off the internetz, check it straight away.
The bung looks ok and just hoping ive ordered the right size.
Rich.T
1,609
932
Done!
Blocked off the hole in the tip.
From the outlet of the catch tank ive got about 6 inches of hose to the puck. Then out of the puck is the pipe that now runs down to the subframe exiting at the rear of the nearside inner arch.
Will run the car for a week or 2 and report back if there are any findings.
bruceR
2,540
616
Monifieth, Dundee
Right I’m f**kin well pi**ed off now
Replaced the drivers lock module this morning with OEM unit (yesterday done passenger side with no issues and working fine). All went well until I finished up and nipped out to shops - found out I couldn’t open either of the front doors from inside or out
I’d forgotten to reattach the inside cable to handle but can’t understand why this would affect both doors. I can hear the locks operating when pressing both keyfob & door buttons!!!!
Came home in a rage and managed to reattach cable by removing inside handle cover however still unable to open either front door from inside or out.
Anyone got any ideas………
Nam-uk
1,111
297
lancashire.
Just picked up a pair of OEM door lock modules from TPS, now waiting for a decent spell of dry weather to get them installed.
got a rear door to do ;) but like the others i did going to strip them down to check and lubricate as aftermarket there dry as a bone, worked well on last one.
Nam-uk
1,111
297
lancashire.
might be a issue with motor jammed in close, my rear done that but in open position
Sl1ced
797
404
Done!
Don’t need the puck if you’re VTA mate. I had a hole on top of my can for a filter. So I’ve used both main inlets for crank and rocker respectively then used the filter outlet to run a hose down and under the car. Made a bracket to attach it to where the old relay box was too
Reactions: Rich.T
Rich.T
1,609
932
Yeh, i know.
I did it as it looks neater. Rather than just having a random piece of black hose in the engine bay ive used the puck more as a T piece.
To be honest, ive found the whole catch tank setup a masive pain in the arse.
Replacing something that worked perfectly before with something that needs constant maintenance.
Ive still got the original pcv system and very tempted to put it back on.
Unless anyone can give me good reason why i shouldn't.......?
Sl1ced
797
404
Yeh, i know.
Ah I would’ve left mine on but all the pipes were like Swiss cheese. Fatigued and split. It was the cheaper option. To be honest apart from turning my drain tap every month I don’t do anything else lol
Reactions: Rich.T
Nathan penney
Active member
Jul 8, 2017
687
790
Liverpool
This has just happened to my front passenger door.
My offside back doors been a bit temperamental for a while, but like the car was punishing me for nearly selling it, went to open the front passenger door on Monday and nothing.
So I need to now sort both. Glad I didn’t sell it I’d have felt really bad on the new owner even though it only happened after the car should have been collected.
LCR AL
82
49
Yeh, i know.
I installed a recirculated catch can setup due to perished pipes etc and performance definitely improved for it.
I was recently looking into a vta setup as can emptying is quite regular and don't like the idea of it freezing in winter, then I read this old thread which explains several reasons why you need a pcv valve, hockey puck and a recirculated setup.
It seems to make sense to me.
So I'm going to re pipe my setup in the near future.
Have a read, see what you think.
Sent from my SM-A405FN using Tapatalk
Reactions: Rich.T
Rich.T
1,609
932
A great link and worth a read if you have a catch tank 👍
I got about half way through the thread and ran out of steam. Not had my 2nd coffee yet lol.
I'll have a read again later. What i did get though is the original setup is best so will be looking at the parts removed and see if its fit enough to put back on. If memory serves, it was in decent nick. May clean the pipes out and replace the little valve.
If its toast, I'll just have to dig deep and replace it all.
Rich
