Tell
Tell
No that file doesn't make any difference you can have it on or off. Navigation card normally goes in the left slot. Have no other cards or usb s in during the workaround. One it's done it's work you can then put in other SD cards / usb it may get confused otherwise.
4096 cluster size. Eu1 maps if the original 16gb card and the workaround. I'd use the latest release I indexed we know that works and VW sometimes messes up their zip process. It happens...
& not forgetting that reboot of the unit, long press on the on/off button till you see the Seat logo appear, fingers off then. That will force it to read all the card and set itself up properly, swapping cards without that within a 20 minute period won't lead to a full read of the card, just a hot boot in old language, you want a cold boot.
17
Yes 2019 Leon Cupra 290 DSG. I've given up for today it's making my brain hurt lol. Probably seems silly to you but it's not easy to do unless you know how. The VW 2025 map was too big for my card 16Gb my card is 14.8Gb.
May 16, 2019
17
Could I suggest something for idiots like me, when you show the list of steps could you put the important "not to do " things in a sort of warning before the list. That way people like me won't read 75% then start trying to do it and make a huge error like formatting the card rather than deleting the maps and replacing them.
Tell
About three years back Vag release all of Europe above the 16gb card. You need the 32gb Vag card that you can get from Ebay but still need the workaround. After about 2-3 years of warning all of Europe wouldn't fit on the 16gb card due to the cartography increasing in size. The zoned regions are released as a substitute but if driving across Europe then you need the 32gb card.
Warnings are fairly liberal but the manual assumes you have mapcare. Saying don't format the card is fairly liberal. Changing the sector size consciencely or via file explorer doing it by accident within the format is another warning.
Basically the unit in the car expects a Vag prepared map card changing the sector size is things that people do when trying to be clever but Vag had thought about that in the zoned release but not the Microsoft bug in some file managers that ignores the existing sector size and chooses one for you which is incompatible... then we have the reformatting trap that hits some people. So best to just delete what's on the card and not treat it like a floppy disk or cartridge...
Walone
1,722
509
Near Heathrow
I did everything in the instructions and tried it but no joy. I then found the SD card format was wrong so I've just reformatted it to 4096 cluster size. I'm going to try the VW site for the 2024/25 version of 2010. The Seat site has so many versions and I have no idea which one to choose. Another thing I probably did wrong was put the SD card into slot2 where it came from. Why slot 1 ?
IMO I don't think it matters which slot it's in.
May 16, 2019
17
There is on ebay a seller with this Seat AS V21 MIB2 Gen 2 SD Card Leon Ateca Ibiza Toledo Alhambra UK EU 2025 Maps for £34.95 free postage. ( Hope this is allowed). They have a phone number too so I'll call tomorrow to make sure it will work.
Tell
Like all ebay purchases you do it on their marked up satisfaction and volume. My 32gb card is a Skoda one that German Skoda board liked at the time. Now they talk about Chinese rip offs 🤔. Basically the official ones used by Vag have a re writeable CID. All Vag CIDs are interchangeable. It would only be if the Chinese ones were not re-writeable in the main area or slow. Speeds probably not an issue. They are probably Vag cards but that's where the reputation score comes in on ebay purchases.
Westindieman
87
9
When I put the updated card in I get a message something like 'the card contains navigation data', then the system goes to checking navigating data with a spinning symbol. I have left it to do this for 5 minutes with no change (dont have time to sit there longer today and have no journeys planned). I suppose the fact that its not rejected means we're on the right lines but is it possible it will not change from that status?
Tell
The key is this one
You carry over the old DBInfo.txt but edit the last two lines to so it reflects the update. The unit locks onto the old partnumbers but for display you need the last two lines from the new maps. You also do it by editing in the Audi lines of the old card into the new dbinfo.txt file. Basically it teethers on the old Audi lines. It's says ok you haven't updated it, I can use this SD card... but you have but have fooled it. The mib1 mapcare workaround.
In the dbinfo.txt file of the update:
PartNumber1="8V0919866B " <<< put old Audi code in here
PartNumber="8V0919866B " <<< put old Audi code in here
In this example it was 8V0919866B on another mib1 year it would be something else.
That's @Daz3d method. In your instance we didn't edit the mib1 countries out but used the mib2 bigger card. That just leaves the edit if we think the 480 firmware is not important.
If it is sting hung might be the sector size. I said 4096 for mib2. These system don't like you messing with the sector size. 4096 should / will be good since we have used it on other mib1s.
Westindieman
87
9
The key is this one
Really sorry but I don't fully get you. The lines on my old card is
PartNumber1="8V0060866H "
PartNumber2="5G0919866AH"
PartNumber3="5E0051236 "
PartNumber4="5F0060884BG"
PartNumber="8V0060866H "
ApplicationSoftwareVersionNumber="0075"
SystemName=" ECE 2018/2019"
on the downloaded file it is
PartNumber1="V03959803RQ"
PartNumber="V03959803RQ"
ApplicationSoftwareVersionNumber="0106"
SystemName=" ECE 2023 "
The last 2 lines are
so do I replace them with the lines from the update while keeping the other lines?
Tell
You need to edit
Onto your new file of dbinfo.txt keep everything else as the new parameters. That makes the unit think you haven't changed the card but you have. You have fooled it. Hence why @Daz3d pointed to the new road on his map after the edit.
Use the notebook editor and make sure you get the spaces in.
You'll need the long press on, on/off to force a reboot if changing the cards quickly.
Westindieman
87
9
You need to edit
Ive got you now thanks, it cant have been the issue though as the 'checking navigating data' with a spinning is still there.
