About three years back Vag release all of Europe above the 16gb card. You need the 32gb Vag card that you can get from Ebay but still need the workaround. After about 2-3 years of warning all of Europe wouldn't fit on the 16gb card due to the cartography increasing in size. The zoned regions are released as a substitute but if driving across Europe then you need the 32gb card.Yes 2019 Leon Cupra 290 DSG. I've given up for today it's making my brain hurt lol. Probably seems silly to you but it's not easy to do unless you know how. The VW 2025 map was too big for my card 16Gb my card is 14.8Gb.
IMO I don't think it matters which slot it's in.I did everything in the instructions and tried it but no joy. I then found the SD card format was wrong so I've just reformatted it to 4096 cluster size. I'm going to try the VW site for the 2024/25 version of 2010. The Seat site has so many versions and I have no idea which one to choose. Another thing I probably did wrong was put the SD card into slot2 where it came from. Why slot 1 ?
Written by someone else before we found the danger of it. Will edit it.The list of steps in your post this morning does say to format the card. Step 7
It did come up once people not pulling out all the cards. I pop them out during an update as a matter of routine. That was their problem. Slot A the left one is the map slot on a mib2 standard.IMO I don't think it matters which slot it's in.
Like all ebay purchases you do it on their marked up satisfaction and volume. My 32gb card is a Skoda one that German Skoda board liked at the time. Now they talk about Chinese rip offs ?. Basically the official ones used by Vag have a re writeable CID. All Vag CIDs are interchangeable. It would only be if the Chinese ones were not re-writeable in the main area or slow. Speeds probably not an issue. They are probably Vag cards but that's where the reputation score comes in on ebay purchases.There is on ebay a seller with this Seat AS V21 MIB2 Gen 2 SD Card Leon Ateca Ibiza Toledo Alhambra UK EU 2025 Maps for £34.95 free postage. ( Hope this is allowed). They have a phone number too so I'll call tomorrow to make sure it will work.
The key is this oneWhen I put the updated card in I get a message something like 'the card contains navigation data', then the system goes to checking navigating data with a spinning symbol. I have left it to do this for 5 minutes with no change (dont have time to sit there longer today and have no journeys planned). I suppose the fact that its not rejected means we're on the right lines but is it possible it will not change from that status?
Really sorry but I don't fully get you. The lines on my old card isThe key is this one
What people use to do with mib1 after they messed it up. The motto is back up before changing anything. I provide a link to the mib2 standard overall.nds file which fixes all of those who have lost that file which provides a universal solution that we worked out here, but there is no universal...www.seatcupra.net
You carry over the old DBInfo.txt but edit the last two lines to so it reflects the update. The unit locks onto the old partnumbers but for display you need the last two lines from the new maps. You also do it by editing in the Audi lines of the old card into the new dbinfo.txt file. Basically it teethers on the old Audi lines. It's says ok you haven't updated it, I can use this SD card... but you have but have fooled it. The mib1 mapcare workaround.
In the dbinfo.txt file of the update:
PartNumber1="8V0919866B " <<< put old Audi code in here
PartNumber="8V0919866B " <<< put old Audi code in here
In this example it was 8V0919866B on another mib1 year it would be something else.
That's @Daz3d method. In your instance we didn't edit the mib1 countries out but used the mib2 bigger card. That just leaves the edit if we think the 480 firmware is not important.
If it is sting hung might be the sector size. I said 4096 for mib2. These system don't like you messing with the sector size. 4096 should / will be good since we have used it on other mib1s.
You need to editReally sorry but I don't fully get you. The lines on my old card is
PartNumber1="8V0060866H "
PartNumber2="5G0919866AH"
PartNumber3="5E0051236 "
PartNumber4="5F0060884BG"
PartNumber="8V0060866H "
ApplicationSoftwareVersionNumber="0075"
SystemName=" ECE 2018/2019"
on the downloaded file it is
PartNumber1="V03959803RQ"
PartNumber="V03959803RQ"
ApplicationSoftwareVersionNumber="0106"
SystemName=" ECE 2023 "
The last 2 lines are
so do I replace them with the lines from the update while keeping the other lines?
Ive got you now thanks, it cant have been the issue though as the 'checking navigating data' with a spinning is still there.You need to edit
Onto your new file of dbinfo.txt keep everything else as the new parameters. That makes the unit think you haven't changed the card but you have. You have fooled it. Hence why @Daz3d pointed to the new road on his map after the edit.
Use the notebook editor and make sure you get the spaces in.
You'll need the long press on, on/off to force a reboot if changing the cards quickly.
Back to the cluster size 4096 and whether the cards works with the original map copy. Then did you update to the latest 480 firmware. Jury was out on whether you needed that.Ive got you now thanks, it cant have been the issue though as the 'checking navigating data' with a spinning is still there.
I didn't update the firmware, ive just read through the update firmware section (2 pages) and don't see anything relevant to my 2013 Seat LeonBack to the cluster size 4096 and whether the cards works with the original map copy. Then did you update to the latest 480 firmware. Jury was out on whether you needed that.
