Any one have the 1989 package?
That's just installed on mine yesterday. So far, the infotaiment was pretty buggy this morning, but seems to have sorted itself out now. I've lost ACC, Auto-Hold and probably a bunch of other features. Have tried a reset this evening, but yet to properly test. Hoping it's a case of just settling down.
Otherwise, I have it already booked in with a dealer to get some other warranty work done.
Hi everyone!
I have pretty old software and no ota update is showing even if I have it connected to wifi. What can I do or how can I update it to get latest software? Only at the dealer?
I'm currently on 1989.
The car however was previously stick on 1790, had a software update manually installed using ODIS and carried out 3 OTA's. (ODIS can't install the newest version.
Gotta go back for the SOS module to be updated too as it has signal drops. However that was already expected we just needed the OTA's to install first.
Previously my infotainment was almost inoperable Slow, Crashing, Unable to connect to the app, Unable to install OTA's. This version works almost perfect however the proximity touch doesn't work currently not really concerned as it seemed pointless anyway and will probably be fixed in another OTA. Although I will ask about it.
Going from an old car with an FM/AM radio this tech seems great but defo has its issues.
Lucky for me I just bought it as a used car so the dealership is obligated to pay for it. Other than that I really love the car.
Hi everyone!
That software is even older than mine was, It likely will have the same issue as mine. Too old so OTA won't function properly.
I'd advise leaving it set to ESim on for a couple of weeks.
If that doesn't work you'll need to have it updated manually via a dealership or someone with the ODIS software.
I don't recommend using software downloaded online as I've seen people use that and lose features as it wasn't correct for the car.
The SOS module will also require an update.
I have seat leon 2020 mk4 with update 1672, please your help to update my software version.
I need firmware work with 1672, i tried 1899, 1940, non of them works.
I think I should upgrade to 17XX first, if you have one.
Nope, when the software is as outdated as yours it will require a professional to carry out an update as even if you could update the infotainment the TCU also requires an update which requires ODIS otherwise you’ll have faults.
@East Yorkshire Retrofits knows about it better than I do.
Reactions: Tell
@LJamH Thanks for your response.
I prefer if anyone has software 17XX, send it to me to try update.
Can everyone commenting please bear in mind that this site doesn't condone the distribution of copyrighted software.
It might be a topic best discussed via the DM function 👍
Well the firmware is held together by sticky tape in the evo platforms or feels like it, so fiddling with it yourself seems prone to errors. The hobbyists have pulled out of mib3 since much of it is now locked down, so backdoor methods aren't there, so if you mess it up, you got to pay someone to sort it out. That's on firmware not on the other updates like radio icons and maps which are user allowed and files provided. Firmware off limits to unauthorised meddling.
I'd just take out a connect services license if I had one of these cars and deposit it on the dealer when it went wrong. Similar to mib2 standard from reading posts upgrade routes dont officially exist and as said higher up you need a retrofitter to change trains. Within trains you get over the air updates even if you dont have connect services and dont hide yourself. Fiddle with the security which people said to do to stop that pop noise means you dont get the free firmware updates or radio icon updates. So if I had one of these cars without a connect services license in Europe where connect services are offered I'd set the security level to myself as me and not go into hiding as people suggested. Bad idea. Get the telematics box sorted out that was generating the pops. That was the 2020 issue that bubbled on for a couple of years. Seat / Cupra were slow to sort it out, so they were all popping at the same point in the road :no:
Now there are people that are fiddling with the control units which I reckon is a very bad idea. Hobbyists doing it so I understand.
Updated from 1969 to 1988, all went smooth, just missing the Radio Logos, I will wait a couple days more to see if some minor update pops up.
Later today I got an OTA update, but still no Logos
Went to Radio definitions and on the favourites I could choose amoung several ones.
Before was all automatic and logos would show, not now, but at least I can see all portuguese radio logos
Already I called the dealer, they ask me to pay around 150€ ( just for check update).
So I'm looking to do this update by myself.
Is the specific update exclusive with dealers ?
There are multiple control modules that all need to be updated together to ensure the correct baseline. You cannot update 90% of them yourself
Visit a dealer or a specialist.
Reactions: moarman and Tell
On my display I don´t have the radio version info, it's blank.
I see that some guys have the version info and anothers even don´t have radio version on the display, is this normal ?
