Current Spec
Engine
K03s Turbo Unsilenced
Jabbasport Custom Mapping
Blueflame Exhaust
Blueflame 3" Downpipe (Wideband Sensor Installed)
BKR7E plugs
4bar FPR
LCR/S3 Fuel Pump
Forge UNOS Manual Boost Controller
Jetex Filter
Filter extended to where battery once sat
CAI (from foglight)
Forge TIP
Large Toyo FMIC
Custom Intercooler Pipework 2.5"
Forge Map Sensor Tube
Coldside Relocation
Forge 008
N75 J Valve
N249 & N112 Bypassed
SAI Removed (Forge Blanking Plate)
Carbon caninster (N80) removed
Gloss Black Rocker Cover
Gloss black Inlet Manifold
ProBolt Rocker & Inlet Bolts (Annodised Red)
1.2l Washer Bottle
Battery relocated to boot
Red Hoses
42 Draft Oil Catch Tank
Transmision
VR6 Clutch setup
G60 Solid Flywheel Conversion
Peloquin ATB LSD
Millers CRX Competition oil
Shift Box Mounted Inside Car
Short shift kit
Chassis
AP Coilovers
OMP Front Upper Strut Brace
OMP Front Lower Brace
OMP Rear Upper Brace
Neuspeed Front ARB Kit
Neuspeed Rear ARB Kit
Powerflex Poly Bushed Wishbones
Powerflex Poly Bushed Rear Beam
Powerflex steering rack mounts
Solid Front Engine Mount
Vibratechnics Rear Engine Mount
Vibratechnics Gearbox Mount
Braking
305mm Brembo Conversion
Grooved Discs
Ferodo DS2500 pads
RBF 600 Racing Brake Fluid
Wheels/Tyres
17" 8J Compomotive MO6 in Orange
Toyo T1R's
Exterior
AeroCatch Locking Bonnet Catches
Colour Coded Rear Bumper
8000k HID's
LED Sidelights
Silvatec indicator bulbs
L.E.D Numberplate Lights
LCR Front Splitter
Widemouthed Front Bumper
Debadged
Rear wiper removed
Carbon Front S Badge
Interior
OMP Corsica 330mm Steering Wheel
OMP Boss Kit
Custom Rear Harness Bar (Made By AKS Tuning)
Nomad Twin Gauge Pillar Pod
Autogauge Boost Gauge
Autogauge Oil Temp Gauge
Autogauge Volt Gauge
Autogauge Oil Pressure Gauge
Stack Wideband A/F Ratio/Lambda Gauge
Sony Xplod Headunit Conversion
LED Interior light & LED Map light
Battery in boot
Stripped rear
The Very Start
Thought i may aswell start a thread
Started in July 2009 when i bought the Cupra
Heres some pics from when i picked her up
After owning for 7 months repair bills have now reached the £1000 mark!!
Previous owners had obviously not cared for the car and quite frankly it turned out to have been neglected!
So far ive changed
Brakes all round
2 wishbones
2 anti roll bar links
2 rear hubs
Wheel bolts all round (absolutely kackered threads)
Full interior
Clutch replacement
Repaired clutch pedal
Gear linkage
Previous owner had 17" supperlegerras on, the car then has rear spacers and the standard radius wheel bolts.
Resulting in wheel bolts barely holding the wheels on, damaged rear hubs and bolts all stripped
Interior was seriously neglected and turned out one seat was crooked, it later snapped so picked up a new interior
The rest are just serviceable parts but obviously had just been left leaving me with the joy of replacing them!
Enough of the problems, some more positive things
First to be changed was the gay lexus lights to some nice fresh standards
Then after replacing
Brakes all round
2 wishbones
2 rear hubs
Clutch
Was time for a rolling road
Was off to Northampton Motorsport for rolling road day
It came back with 186.6@ flywheel
and a very healthy 222.7 torque figure
Rather happy with the figures only having a mild map (15psi peak)
Then i focussed on the bay a little bit
Replaced the 007p with a turbosmart
replaced blue vac lines with red
added some more red
Replaced cheap ebay filter with a Jetex
Silicone extension
Coldside relocation
Sprayed strut brace
Heres the engine bay before
Engine bay after
Engine
Blueflame Exhaust
BKR7E plugs
4bar FPR
LCR/S3 Fuel Pump
Jetex Filter
CAI (from foglight)
Forge TIP
Large Toyo FMIC
Coldside Relocation
Forge 008
N75 J Valve
1.2l Washer Bottle
Red Hoses
Transmision
VR6 Clutch setup
Peloquin ATB LSD
Short shift kit
Chassis
AP Coilovers
Braking
Grooved Discs
Ferodo DS2500 pads
Wheels/Tyres
Toyo T1R's
Exterior
8000k HID's
LED Sidelights
LCR Front Splitter
Debadged
Rear wiper removed
Interior
OMP Boss Kit
Battery in boot
Stripped rear
The Very Start
So far ive changed
Brakes all round
2 wishbones
2 rear hubs
Full interior
Clutch replacement
Gear linkage
Brakes all round
2 wishbones
2 rear hubs
Clutch
added some more red
Silicone extension
Coldside relocation
Sprayed strut brace
Engine bay after
