Advice On Modifications...
Status
Not open for further replies.
Chris_a_73
1.2L Ibiza Mk4 '07
Oct 27, 2009
1,947
Guildford and Bristol (uni)
You're able to get 5000k versions of those :D http://cgi.ebay.co.uk/H4-New-Osram-..._CarParts_SM&hash=item45f41a1660#ht_718wt_911
I've basically taken a few pics just to show the colour of light and types of adjustment for best match between minimal road lighting and maximum plate visibility.
Too much road lighting;
Still a little too much;
Too little;
Ahhh about right!
Chris_a_73
1.2L Ibiza Mk4 '07
Oct 27, 2009
1,947
Yep, easy as that. You basically have to tilt the light to a 45 degree angle towards the car. Imagine \ is the light pattern of the LED and | is the plate. Almost as if the light ain't even pointed at the plate, more above, at the fixings.
\ (light)
| (plate)
Chris_a_73
1.2L Ibiza Mk4 '07
Oct 27, 2009
1,947
I personally couldn't recommend any of them, as I don't own any of them. I can only go from what the website and google tells me to be honest. I think the Nightbreakers are the brightest, however Cool Blue 5000k would be more HID-like, although not as bright. Just more blue.
Mar 19, 2010
1,324
I have 2 bulbs in my ibiza , one for low and one for high , what bulb type is for high ? I already have a h7 hid kit for it , and im guessing this is for low beam
marksy93
In an Ibiza..FR This Time
Aug 26, 2010
838
N.Yorkshire
ok :)....another quick question i fitted the aluminum gear surround but now my gear knob :lol: (sorry) is loose, how do i tighten it up? also if i bought a gear knob off a golf or similar would it fit?
Dec 3, 2009
1,638
there's some metal clips bit, once you bent it to get it off you can't put it back on :(
have to buy a new one I think/jubliee clip it ?
Chris_a_73
1.2L Ibiza Mk4 '07
Oct 27, 2009
1,947
I believe it's held under the jubilee clip...not sure! Definitely not sewn into the actually gear knob though. Can't remember :shrug:
Did you fiddle with the gear to make it loose, or was it just like that after you fitted the surround?
I guess you did reconnect the two clips at the back of the gaitor to secure the surround?
Status
