just fitted the ripspeed air filter but no t very load when driving, but can here it loads inside of the car when the windows are closed is that normal, wud it matter if it was a cosed filter, wud that make any difference????
gus
Are you kidding?
You bought a ripspeed filter??
lol
The first thread was a piss take not advice.......
so either a cone filter, or a pipercross filter and a braether for the pipe which connects to the air box will create that sound?? am i correct????
and is there a carbonia induction kit 4 the ibiza cupra? as i no tghere is 4 the golf 1.8t?
gus
Any opencone filter will give you the sound mate. I have a dynatwist (closed induction) but have the heatshield off & the whoosh sounds great.
You will NEVER getr the sound of an RS Turbo, Scooby etc etc. But you can get a decent whoosh on an ibiza.
gus
Gus, let it wear in, It will get a little louder but dont expect anything special.
Also remember that the sound comes from the front of tha car so u wont hear it as well inside the car as if you would standing on the street watching it go past.
Get a mate to test it in a carpark & listen to it from the outside! Or go in a tunnel
gus
Have u changed the dump valve? Or have u still got the standard Bosch unit on there?
Failing that just defy science & buy a blow off valve instead
gona get my dump valve serviced tomorw and ive got the 007dv does sound good but the open cone filter does not sound as load as the normal filter...
will servicing the dump valve make it louder???
gus
gus
Gus, how long have u had the dump valve for mate?
If its new u wanna let it run in a bit. Mine was silent when I got it, no whoosh what so ever, Slowly over time its got louder & now that its run in properly it sounds pretty decent.
Like I say tho dont excpect it to ever sound like a RS Turbo, Starlet GT, rENAULT 5 or anything like that cos it wont.
Where are u based? If your near enough No Rice is on tonight, pop down there & see other SEATs & see what they have & how it sounds on other peoples cars.
Remember as well the dv will be louder outside of the car than it will inside of it.
dv
live in coventry so where near u there not many cupras which i have seen in the covenrty area but my noise aint to bad my mates 1.8t golf sounded the same as mine when he put a induction kit on so will have to live with wat ive got, the sounds wicked dont care if i sound like a kid!!!! ahahhahahahahaha
gus
both piston tho int they
Bailey has plastic piston, Forge 007P is aluminium. (and lifetime warrantied)
I had Bailey and it wore out fast. O-rings wore ruts in the ally top would you believe.
No difference to sound between em
Agreed my Bailey lasted a year then I threw it away (non-servicable) and that was £100 down the drain and I bought a Forge which was excellent. No sound difference between the two I tried :shrug:
Bill did warn me but I didn;t listen :redface:
In fairness Syphon ran a Bailey DV for 2-3 years without any problem....sounds like Bailey is nearly as much of a lottery as the OE Bosch one
hey all. new to this...
picking my black ibiza cupra up saturday 30/09/06.... can anyone tell me if it comes with a standard dump valve? may seem a dumm question i know.. and where's the best place to buy an aftermarket DV from,
any help appreciated.
Laurence
Laurence
Is the car standard? It will come with a standard Black Plastic Bosch Dump Valve as standard! The one most people upgrade to is the Forge007P which you can get in Black or Polished Silver
Have a word with Bill Brockband at Badger5 and he will sort you out ;)
whats wrong with just simply drilling your standard air box? that should give you some sort of whoosh should it not?
