hi guys as the title really, falied mot on cv boot(which ive replaced myself), looked at the ball joint also but struggled like hell, also ran outta light!
what im after is some tips on how to replace the lower suspension arm balljoint, ive had a go but to no avail.
basically i popped the drive shaft out( needed to do cv gaitor anyway), released the wishbone bolts and extracted the full arm....
couldnt for the hell of it release the ball joint, i see it has an allen key setup, but any way to change this easier fellas, sure someone has done this......
thanks in advance
thanks in advance
Pressure bled using an ezibleed. The trick is to not let air up the brakelines on the body - if you avoid that, you only need to bleed the calipers.
