give me a few weeks, then PM me
ill be able to tell you which the best way to do it is
two type of spacer you can use
Rik, any chance you could post back here with the solution also. I am considering a full system soon and would also like to see what spacers you got/used for future reference.
Just orderd mine. Click the big button see the catalog then select part number search search them part numbers and jobs a gooden!!
£11 - Bargin
i ordered some of these from rockauto
came real quick and i sent one set to someone on here who used them and worked-you have to bore out the top
i then found a guy in Minnesota that makes a piece that turns the lamda on a right angle to the exhuast so you dont get ground clearance issues like you MAY with spacing it straight out.
that took about 3 weeks to appear, just waiting for the fitters at work to put it on when the pit becomes free
if id known all this before i fitted it i would have ordered these and put it on the exhuast from day 1
Bolox i forgot about that sensor.. There is a guy on VW Vortex than can make them i PMed him.. and forgot to check... ops.. i spose i best check them now
If you've been researching the stacked non-fouler mod as well as my angle block, you probably have a good idea of how this works. When you add a high flow cat and larger diameter exhaust, the secondary O2 sensor "sees" more exhaust and
then tattles back to the computer since it thinks something is wrong. By merely pulling the nose of the sensor (secondary--never primary) out of the direct exhaust stream, it basically simulates having the smaller exhaust/OEM cat again. The beauty is that it is a mechanical fix--if it needs to be set back to stock, it can be
with the rockauto bits, the top of the two spacers needs widening about 15mm to take the lamda probe
hth
I don't like the though or boring or drilling the exhaust, is there no straight plugin/bolt on option?.
no its the spacer you drill/bore, these then just sit into the lug in the exhuast where the sensor would normally go
aghhh that aint to bad then. I didn't fancy touching the exhaust if I'd only just bought one. Like you mentioned I'd have liked this sorted from day 1 so no further problems down the line. :)
