Boot Light and Glovebox Light Parts list and vague instructions...
joonspoon
175hp. 275lbs/ft.
Nov 18, 2006
361
Oxfordshire
think Im going to dismantle the dash and connect it at the switch.
Do you mean the door switch?
On my car the switch is combined with the catch/lock so I'd have to remove the door panel to gain access! :(
Perhaps that's caused some of the confusion on this thread? :shrug:
Guy.
BlackFR
1,727
7
Not too far away
Took the "A-pillar" trim off on the passenger side but wires do not feed up behind there so supply has to be from below the dash.
No it doesn't. You can also splice behind the interior light.. Pipe the wire through the head lining and then down the A pillar you took off... Thats the easiest way to achieve an electrically identical set up to that that was used as standard.
Glad you got it going and the part numbers were useful! :)
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
explain black what I do just with a bit more info, as im going to do this tomorow I think. i get most the wiring, but where is best place to connect positive, and best way 2 get it there, also where is the best place 2 ground it. Thanks lads
BlackFR
1,727
7
Not too far away
Hi Guinness
Just went out and took a couple of pics:)
Here is my power connection:
And GND connection:
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
ah right thanks mate, al grab some bits from college today, just run in like am getting the shopping 1 roll solder, heatshrink, few metres of wire. see if anyone notices lol Chears again appreciate it
R1ch85
1/4mile - 13.935 @ 100.54
Nov 9, 2006
1,675
Bristol
SEAT SENT THE WRONG PARTS! :censored: [:@]
But now I have a new reference number.
Prices for the glove box parts.
3B0 947 415 Lamp £4.84
1J0 947 561 Switch £2.22
893 971 632 Housing £1.23
1J0 973 119 Housing £1.23
000 979 133 Cable £0.93
000 979 131 Cable £0.93
With VAT the total cost is £13.37.
Guy.
why are dealers such a pain in the ass? :ban: ordered the above parts monday, got a call today saying they had arrived, went to fetch them and the 2nd housing part isnt there and i only got 1 of each cable! :censored: now im gonna have to wait until monday before i can get the 2nd housing and sum more cables!
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
mines pretty good up here must admit never get any probs always get his 10% off and got a random sensor last time given in with everything was wondering what it was I hadnt fitted
R1ch85
Nov 9, 2006
1,675
Bristol
ok, before i phone up the dealers tomorrow to order sum more cables, can somebody please clarify exactly how many of each i will need? i currently have one of each
many thanks in advance!
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
erm you need the amount joon quoted but if you want to run the wire to the interior through headlining then you need to extend cable.
joonspoon
175hp. 275lbs/ft.
Nov 18, 2006
361
Oxfordshire
You need 2 of each wire so just order one more of each. :)
000 979 133
000 979 131
Take one of each wire and cut in half.
Join one half of each type to make one wire with a different fitting at each end.
I've done a how to guide with a parts list here.
http://www.seatcupra.net/forums/showthread.php?t=110282
If you're connecting to the interior light you'll also need about 1.5 metres of single core wire so that you can route up behind the headlining.
If you need any help PM me or post in the guide thread.
Regards Guy.
R1ch85
Nov 9, 2006
1,675
Bristol
000 979 133
000 979 131
Regards Guy.
Thanks, much appreciated! :)
