cheers mate. yea will definitely contact you for tips on losing weight lol.
In the absence of weight pure mechanical grip will take over.Surely you need the weight now otherwise you will lessen the traction? Doubt you need it to be faster?
Hay you you cheeky wee scampor haldex
but I guess that would just add weight eh willie?
With KW clubsports and R888's handling will be imense
with this amount of grunt tractgion will always be a problem, an educated right foot will solve this
wer abouts in leicester are you from mate is yours the 53 plate i keep seeing
i am in thorpe astley not got mine yet am in the process of saving up the ££ should have one this year sometime wont be anywhere near as mad as yours though.lol
I take your point WillieIn the absence of weight pure mechanical grip will take over.
I did find initially when all the weight was removed over the back wheels it was feeling like it wanted to swap ends under hard braking. I adjusted the tyre pressure down 3 PSI and the balance is fully restored again. I have MASSIVE confidence in my cars handling nowI take your point Willie
However The problem with stripping hatches like Leon is most of the weight is removed from the rear so I think it may unbalance things. I am no expert however so just going on what I been told/read and experimentation with my car.
Thats why if you have coilovers you get them corner weighted set up.... this will balance the weight around the car by altering the height of each coilover untill the weight is shared around each corner equally!
Transforms the handling!
saw a KTM Xbow at Springfest and noticed a BDM 350 on the side
was that you then?
(pic courtesy of me mate jon, photographer extrordinaire)
