Hi, tried to enable the alarm chirp for open and closing with Carista but doesnt work, any ideas anyone do i need to reset settings in the mib.
Car is a 2016 Cupra 290.
That’s great, had to go into the MiB factory settings and reset the mirrors but works now ?Not sure. I know that with some features, you need to activate them in Carista and then turn them on in the MIB. I did mine a while ago so can't remember what I did.
I've just installed the Carista app but it doesnt seem to work with my OBDII adapter "Zus Smart Vehicle Health Monitor Mini". The Carista app just says "faulty adapter" but it does show the battery voltageI got the adapter for free so not a big issue but .........
Perhaps i'm doing something wrong. Anyone managed to get the Carista - Zus Smart Vehicle ..... combo working?
Personally, like I'm currently doing get to know your car before fiddling!Hi everyone just taken delivery of my 2018 184 and just wondered what were the best things to do on the carista app ? Also does the forced regeneration of the dpf actually work and is it recommended. Do you have to drive the car afterwards or does it do it on its own idling ? Thanks again
Why do you need to do a forced regen? I'm not sure I'd want to use the app for that. Is there an underlying issue with the car? A forced regen is last resort if a passive or active regen don't work.Hi everyone just taken delivery of my 2018 184 and just wondered what were the best things to do on the carista app ? Also does the forced regeneration of the dpf actually work and is it recommended. Do you have to drive the car afterwards or does it do it on its own idling ? Thanks again
If for example on the VAG DPF app I can see it's 90% full and I've got 20 minutes motorway driving left, it would be good to get a regen started. Otherwise by the time it gets to 100% and starts the regen itself I'll be in town traffic.Why do you need to do a forced regen? I'm not sure I'd want to use the app for that. Is there an underlying issue with the car? A forced regen is last resort if a passive or active regen don't work.
Ref other `tweaks` - my car is 2014 so may be different to yours:
- Ignition on needle sweep
- Alarm chirp
- Always on rear DLR
- Mirror fold on locking
I'm sure there are a couple more but I've forgotten.
Some items you just activate in Carista and others it activates in the car menu and you also need to turn it on using the car menu.
In a word - no.If for example on the VAG DPF app I can see it's 90% full and I've got 20 minutes motorway driving left, it would be good to get a regen started. Otherwise by the time it gets to 100% and starts the regen itself I'll be in town traffic.
Wouldn't it be better to get the regen completed on the motorway in that case?
Hi mate I do alot of miles bit short trips many stops and it's something I wanted to keep an eye on and if need be force the regeneration before it becomes a problem. My understanding if it starts when you stop the car it won't work and de completelyWhy do you need to do a forced regen? I'm not sure I'd want to use the app for that. Is there an underlying issue with the car? A forced regen is last resort if a passive or active regen don't work.
- Alarm chirp
If the car cannot complete a regen through either passive or active, the DPF light will eventually come on. At that point you can take it for a 15-20 min run at about 2500 to keep the exhaust nice and hot and let it do a full regen. Thst should reset everything.Hi mate I do alot of miles bit short trips many stops and it's something I wanted to keep an eye on and if need be force the regeneration before it becomes a problem. My understanding if it starts when you stop the car it won't work and de completely
If you have auto lights & wipers, they'll be accessible by default, without you having to "enable" them in Carista. If it doesn't have those functions, there's nothing to enable.Hey guys;
Looking at 18 FR Tech ST (184) and obviously a lot of this takes my fancy.
Are auto lights / wipers something that can be done on this model? I know it says something about if the sensors are fitted - albeit I’m not sure what I’m looking for (in terms of a sensor), my existing Kuga has a big block by the interior mirror but I can’t seem to see this on a Leon?
This is the type of sensor i have, any ideas on what it is ?If you have auto lights & wipers, they'll be accessible by default, without you having to "enable" them in Carista. If it doesn't have those functions, there's nothing to enable.
Not sure there's any sensor at all there, mate. Just took a photo of mine with the sensor in the middle. You'll have a little square if you feel the back of the mirror, that's the auto dimming sensor but that's your lot.This is the type of sensor i have, any ideas on what it is ?
It looks like you are right !!! Just a blank space there ! I wonder if aftermarket light sensor can go there to keep it all looking like from factoryNot sure there's any sensor at all there, mate. Just took a photo of mine with the sensor in the middle. You'll have a little square if you feel the back of the mirror, that's the auto dimming sensor but that's your lot.
I'm not sure that would be an easy job mate, if you wanted it to look factory fitted. You'd have to change the unit, additional wiring, switch etc.It looks like you are right !!! Just a blank space there ! I wonder if aftermarket light sensor can go there to keep it all looking like from factory
