Colour coding door handles: anyone done this ??
RaggedLob
The worst is yet to come
Mar 29, 2009
179
Thatcham, Berkshire
i'm doing the rubstrips this week, and am thinking about doing the handles..
anyone found anything to get the waxy layer off the plastic? or shall I just spray it on regardless?
Mar 16, 2008
692
Wiltshire / Bristol
Yep. Put a few coats of primer on and sand down with wet + dry to get it nice and smooth and remove any imperfections. Then paint as usual. You might want to put a few extra coats of lacker on though due to the high amount of use they will get.
Neo
Fool member
Mar 24, 2009
881
Rub down the handles with 400 wet+dry to provide a key for the primer, after priming rub down with 600 wet+dry, prime again, then rub down with 600 wet+dry, then colour coat, then rub down with 1200 wet+dry, colour coat again, rub with 1200 (if necessary) then at least two clear coats(laquer). (two coats of everything).
You should always use wet+dry paper wet - soak it in water first, and rub gently after each coat, if you take too much paint off you can always do another coat.
Build up paint slowly (couple of sprays at a time), and leave each coat to dry till next day, if you don`t prepare each stage properly - because of the heavy use the handles get it will start coming off and look c**p!
Spraying is 90% preperation :)
