Engram
Does anyone have a picture that shows where you connect the pressure hose from a boost gauge to the Cupra 180 engine?
I've searched high and low but I've never found a picture for the petrol engine, only the diesel.
Thank you!
Hmmm.. now where is that shiny metal bit?!!
Thanks mate. I shall go and look at the car with that picture in hand and see if I can locate it!
Does the "green nipple" feature in the Cupra 180 engine? Or is that a diesel only thing?
Argh! I don't have something like that picture. Although I do have similar things.
Is the hose I need to intercept the one I've outlined in this picture?
Engine bay picture
I'm just guessing really. (As you might be able to tell!)
the picture that daniel owen has put up is of a forge recirculating valve007 so yes the vaccume pipe you have dotted is the correct one! should get a fittiment in your boast gauge kit to let you connect into it! T piece
fr engine so the same and you can se the boost gauge tap off
