Cupra137 Hybrid II Track Project
Apr 28, 2009
723
Aberdeenshire
Took longer than I thought but there on :D Need bled and a few touches and il be happy enough.
And one for size comparison
Wheels getting resprayed/refurbed soon as not keen on silver on silver
Apr 28, 2009
723
Aberdeenshire
Not really progress as Im still waiting on one of the calipers coming back from a local garage as bleed nipples were fooked, but I thought it was time to fit my TT charge pipe iv had lying about for months.
(Yes, that is a Dominos pizza box. AKA 'Poverty spec spraying booth'
Looks a bit tidier, need to remove the carbon canister next as its never something thats really bothered me but it will help with aesthetics.
Also removed the rear seat belts so it'll get throught its MOT, and gives me some welding points for the cage.
Theres light at the end of this tunnel
723
Aberdeenshire
So finally got the car out the garage at the weekend. Went for a wee drive after it'd warmed up, probably only a 15min low boost run but noticed the brakes were binding quite badly (could stop on a hill and the car wouldnt roll away), so I need to investigate that again. Also the more worrying issue I have is the amount of heat under the bonnet after this short run was insane. Still read 90 on the dial but it was so hot I couldnt touch the strut brace. I know these turbos run hot but surely somethings not right here?
Apr 28, 2009
723
Aberdeenshire
Yeah, il be the one at the side of the road in fire if i cant figure out this heat issue. Buying a new CTS as i know it needs one but i wouldnt have thought that would have contributed to it that much.
Apr 28, 2009
723
Aberdeenshire
Some pictures from the weekend it finally left the garage
Going to remove the brakes again and check the pad clearance, might be needing rubbed down slightly as were quite sticky, and will have to keep an eye on the engine temperatures for now.
I think i have an addiction...
Apr 28, 2009
723
Aberdeenshire
She's done (for now)
Had her booked in for MOT on the Thursday which gave me time to sort out a few niggly things and pull a few more bits off. So after a stressful day the garage phoned to say it'd passed first time! Not bad for a 14 year old car.
Been using her as a daily for a week or so now and its spot on, got it properly logged last night and i couldn't be happier. Makes full boost at 2950rpm and holds steady across the rev range, if i get the logs through il post them up, but all i can say is these hybrids aren't slow at all :drive1: ...
20140526_194845.jpg.html
20140526_194828.jpg.html
20140526_194824.jpg.html
