A little cheat I learnt a while ago was to use Hi tack roof flashing, It is basically the same as the expensive soundproofing but a lot cheaper and it DOES work.
Should of told me before, we got loads of that stuff at hoebase, could of given you a 20% discount! :D
But if you need any more for the doors/boot etc. i'd be happy to help/steal some
Cheers Will, My Mrs work's at the Catford one ;) It's still cheaper at wikes though, £7.30 for 10 meters :D
What did you use in your's ???
ahh bonus then!
Erm, I haven't actually done any yet lol
I saw the idea of this flashing tape on talkaudio but never got round to doing it :ban:
A few more little bit's done today.
Started off just intending to fit my rear strut brace but as the whole boot had to be striped I thought I might aswell soundproof it while it was all out.
Firstly seal up these little bugger's [:@]
Just be mindful how you shut the doors;)
mate where are these vents as i really need to seal mine up they sound cack from the out side
They are down behind the rear wheel arch's, you need to take out the back trim panel, the rear quarter trims, the parcel shelf supports and the side carpet's
I think these are the vents to save the pressure build up when closing the doors. Too much pressure = popped ear drums or not able to close door
:) oh, just have to open a window before you close the door then, ha.
Small update
I recently bought a set of Forge polished Strut caps, Oil cap and Header cap covers from Unclefester
Strut caps, The one on the left is before I let the polishing mops loose on it
Fitted
Oil and Header caps, These had'nt been polished
Fitted
And a bit of Free advertising :whistle:
I'v recently been getting a nasty knocking noise coming from the front nearside wheel area so I poped into AmD Essex today to get it checked over, after a lot of rocking the car on the clutch and a bit of head scratching the boy's traced the noise to a loose gearbox mount, God know's how that cam loose but it's now tight and I have no more noise :D
