Here are a few of the logs you wanted, Dave..
First run is how I have been running lately. Timing set back to 0 and boost turned down, as I have been running 95 fuel due to the lack of V-Power up here :( Its currently running 97 though.
Code:
Group A:	'115				Group B:	'114
	Engine Speed	Engine Load	Spec. Boost	Actual Boost		Eng Load Call	Corr. Load	Engine Load	Bypas Dut Cyc/0-100%
TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar	TIME	<=150%	<=150%	15-150%
STAMP	 /min	%	 mbar	 mbar	STAMP	%	%	%	%
0.37	2440	85.5	1700	1060	0.01	191	189.6	47.4	0
1.29	2640	85.1	2160	1600	0.89	191	189.6	111.3	85.1
2.09	2920	85.1	2170	2080	1.69	191	189.6	151.1	85.1
3	3360	85.1	2110	2210	2.49	191.7	189.6	174.4	85.1
3.81	3800	85.1	2080	2180	3.4	191.7	191	179.7	85.1
4.69	4200	85.1	2070	2200	4.29	191.7	189.6	181.2	85.1
5.61	4600	85.9	2020	2000	5.11	186.5	185.1	182.7	85.1
6.52	4960	87.1	2020	1970	6.01	179.7	177.6	172.2	86.3
7.32	5240	87.5	2060	1970	6.92	174.4	173.1	170.7	87.5
8.12	5520	87.5	2060	1920	7.72	170.7	168.7	169.9	87.5
8.93	5800	87.5	2050	1840	8.53	167.7	165.7	158.6	87.5
9.73	6040	87.5	1980	1830	9.33	162.4	161.2	154.1	87.5
10.63	6240	87.5	1920	1830	10.15	157.1	155.2	150.4	87.5
11.56	6440	87.5	1850	1780	11.04	151.1	149.3	148.9	87.5
12.45	6600	87.5	970	1750	12.05	146.6	144.8	139.8	87.5
Tweeked the boost a little more for the next run..
Code:
0.01	2640	0	970	990	0.49	191	189.6	88.7	85.1
0.89	2760	85.1	2090	1390	1.29	191	189.6	147.4	85.1
1.71	3080	85.1	2170	2090	2.2	191.7	191	191.7	85.1
2.7	3640	85.1	2100	2370	3.11	191.7	189.6	186.5	85.1
3.51	4040	85.1	2080	2230	4.03	188.7	186.6	188.7	85.1
4.52	4520	85.5	2040	2130	5.02	179.7	177.6	183.5	86.3
5.42	4920	87.1	2060	2160	5.83	174.4	173.1	181.2	87.5
6.23	5240	87.5	2070	2140	6.63	171.4	170.1	177.4	87.5
7.03	5520	87.5	2060	2040	7.45	168.4	165.7	166.2	87.5
7.85	5800	87.5	2050	1940	8.35	160.9	159.7	160.9	87.5
8.75	6080	87.5	1980	1930	9.15	156.4	153.7	154.9	87.5
9.56	6240	87.5	1910	1890	10.04	149.6	147.8	151.9	87.5
10.46	6480	87.5	1850	1890	10.86	146.6	144.8	154.1	87.5
11.26	6640	87.5	1830	1860	11.68	146.6	144.8	143.6	87.5
Tweeked the boost a little more for the last run..
Code:
Group A:	'003				Group B:	'114
	Idle speed	Air mass in	Throt Angle	Ignit Angle		Eng Load Call	Corr. Load	Engine Load	Bypas Dut Cyc/0-100%
TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME	<=150%	<=150%	15-150%
STAMP	 /min	 g/s	%	 °BTDC	STAMP	%	%	%	%
0	2800	40.11	16.9	26.3	0.5	191	189.6	135.3	85.1
0.9	3080	111.81	100	12.8	1.29	191.7	191	191.7	85.1
1.7	3520	137.72	100	6	2.1	191.7	191	191.7	85.1
2.49	3960	153.92	100	5.3	2.91	191.7	189.6	191.7	85.1
3.31	4360	152.83	98.4	6	3.71	183.5	182.1	183.5	85.5
4.22	4760	163.25	100	11.3	4.62	176.7	174.6	180.5	87.1
5.02	5040	168.28	100	7.5	5.42	172.9	171.6	169.2	87.5
5.82	5360	172.97	99.6	11.3	6.24	169.9	168.7	164.7	87.5
6.74	5680	173.72	100	13.5	7.13	165.4	164.2	160.2	87.5
7.53	5920	176.22	100	15	7.93	159.4	158.2	154.9	87.5
8.35	6160	178.94	100	10.5	8.75	154.1	152.2	153.4	87.5
9.25	6360	181.78	100	11.3	9.66	148.9	147.8	148.9	87.5
10.06	6520	180.14	100	11.3	10.46	146.6	144.8	141.4	87.5
Look at the throttle angle.... Its back to normal :shrug:
I think it was the gasket that was causing the big dip, but I've got no idea what was causing the wierd throttle angle mate :shrug:
This is all I realy have mate
Not really mate, i just searched your thread there managed to find one on the guide you made about removing the SAI :) Well i was washing the car today and peaked under the bonnet as i was going to run my DV in the reversed position but decided i couldnt be bothered doing it then as i had just finished an hour at the gym came home then set about washing the car! Well after looking under the bonnet it dawned on me that these are pretty messy engines, alot of wires going around and most of them are not needed.... sorry im just rather bored :D
You mean this thread :) http://www.seatcupra.net/forums/showthread.php?t=200030
It looks even cleaner than that now mate :) I'll grab a pic tomorrow for you..
Yep thats the one, ended up finding it in the end :p
That would be magic bud :)
Got to get the car booked in for an MOT and servive within the next 2 weeks but after that i will make it down your way for a few changes to the car then off to P-Torque for a map ;) i dont see any other option than for Will to map the car now..... great price and print out of before and after dynos :)
