First of all, I am sorry, but because I have less than 15 posts I am not allowed to post any attachments. If there is somene willing to post the pictures, I will email them to him. Note that my car is a left hand drive, so the cable colors may not be identical. If this happends, the + is always a thick cable, connect the wire to + and try with the other cable to identify which pin lights the lamp when the door opens.
Necessary products:
- glove box lamp code 3BO 947 415B (with bulb) or 4E0 947 415 (with leds)
- connecting cable code 000 979 131 A
- connector code 893 971 632
You will need one lamp, two connecting cables and one connector for each door. You can do it just for the front doors or for all four doors.
You connect the wires as follows:
Front:
- driver door: + is red/white and - is white/green
- passenger door: + is red/green and - is white/green
Rear:
The cables have to be connected in the connectors on the B pillar, or at least this was the case for my car, since I have electric windows only for the front doors, so there is no confort computer in the back doors.
+ has to be connected in the black connector, on pin 2
- has to be connected in the blue connector, on pin 3, cable brown/yellow
