fitting my new blueflame
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
Hi folks, i just bought a turbo back blueflame exhaust for my cupra R, just wondering if i need a new gasket for between the turbo and the downpipe before i remove the old exhaust and realise that i dont have a gasket it
cheers owen
grey_uk
gaskets
What about the other joins in the exhaust i.e. dp to cat and cat to silencer? do you need gaskets for these?
Balf2k
208
South East Kent
No no gasket needed for any joins after the downpipe, use some clear all purpose silicone like you buy for your bathroom and smear a thin coat on the mating surfaces. Makes a perfect seal and it's easy to get off if you ever take the exhaust apart. Don't worry, the silicone will not melt / burn, it smells for half hour or so for the first time the exhaust gets hot and may smoke but it WILL stop after a short period.
Yumann
1,638
Glasgow
Bathroom silicone for 700 odd degrees :wtf:
Use new gaskets and some exhaust cement also. Locking nuts dont use nyloc use crushed lock nuts
Mitchy
TTRS
Oct 12, 2004
2,310
Has anyone had any problems with fault codes and the 100 cel cat?
Im now and again getting 2 codes related to the efficiency of the cat. Luckily i have a fault code reader and just wipe them straight away but ive had them pop up twice in 2 weeks now.
Also ive noticed it breathes and pulls better up the top end but i do feel its a little more sluggish down at the bottom end, there seems to have been a trade off, either for more lag or a drop in low down torque?
Its 3'' going into 100cel cat and mating up with supersprint cat back which i think is 2.75''
Also when cold, exhaust is quite a bit louder but it settles down when warmed up
Are these normal symptoms of this BF setup?
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Can I add to Mitchy's questions and ask about the MOT side of things? Do the 100 cel cats always pass an MOT? Or do you need to switch back to the standard cat for test time?
Mitchy
TTRS
Oct 12, 2004
2,310
Will find out next year when i go for mine but been told they sail through emissions test.
Yumann
1,638
Glasgow
My one throws codes every now and again saying dodgy cat and thats with a 200 cell. Not every 2weeks tho. Also been for mot and passes no probs.
With my miltek it is a lot louder when cold and tends to pop a bit too.
Mitchy
TTRS
Oct 12, 2004
2,310
Ive had a few pops aswell when giving the car a good ragging. It sounds like the same pops i used to get from my scooby when it threw a flame out the back end. I wonder if my LCR is spitting a flame now and again:shrug:
Its much better up the top end now though, it does make it rev easier and the turbo spools quite a bit louder than before.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
mitch i assume this will help you...
http://forums.vwvortex.com/zerothread?id=2657329 (read all!)
http://forums.vwvortex.com/zerothread?id=1366095 (read the first and last page!)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
cheers owen
the 2 part numbers you need...
N903 690 01
8L9 253 115A
which are for the original DP crush gasket and three 10mm locking nuts
its about £7 all in from memmory... and despite what Scott has said re the locking nuts (which are £2 each!) i would still use them rather than normal locking nuts as the only locking nuts i have seen have had blue plastic lock bits where as these looked more like brownyblack metal if u see what i mean?!)
obviously its up to you but for a few pence more its not worth the risk IMHO!
hope this helps! :)
Mitchy
TTRS
Oct 12, 2004
2,310
Hmm:think: Cheers J@mes:)
It seems like a lot of fecking around just to clear the light that pops up now and again (ordering from US etc)
It only takes 2 mins to clear the light so i think i'll just bare with it.
So is it the DP thats causing the problem, or the cat? Surely something BF should have taken into account when designing it as its obviously not right!
DPJ...Do you get the same fault codes?
Mitchy
TTRS
Oct 12, 2004
2,310
J@mes.... How long does it take to do this? Is it a 5 min job with correct part?
Is Wayne's solution the best in your top link and does it just screw straight in?
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Hmm. Cheers J@mes.
So is it the DP thats causing the problem, or the cat?...
assuming your getting the same sort of codes i had (cat efficiency etc) then this is due to the DP/CAT being a performance one/freer flowing than oe and thus the car/lambda probes realises it, but as a result thinks the cat is fcuked when it is not.
by not spacing the rear lambda probe you will be constantly clearing codes and the car will be adapting all the time right?! so surely its worth the hassle of getting a non fouler sent from the US?! its a 30 min job max to fit! definitely worth while, especially with ur new turbo chucking out more gases once mapped?!
my 2p
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
waynes solution is basically the same as the "Help" spark plug non foulers i bought, but about double the price (waynes is $30, where as the TWO different help parts are $15 together, plus u get two of each part u need so u can sell that!)
i gave mine to scott, so sorry... i knew i should have bought a few! :whistle:
i can pm u the company i used if needed?! (think it was rockauto.com)
cost me £12 i think shipped to my door. i payed for the cheapest shipping which was meant to take about 2 weeks or so, but i had it on my door step in 3 days! i couldn't believe it! :yes: :dance:
as for fitting they are both the same, they screw into the cat and the lambda probe screws into it, BUT the Help parts need to be carefully drilled out so the lambda probe can fit into it properly, whereas waynes is ready to go!
