Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Hat jemand eine Offline-Upgrade-Datei? Falls ja, bitte per PN senden. Vielen Dank im Voraus.
Does this work on a Leon with H56 and 1969? Thanks in advanceПрошивка Cupra – Google Drive
drive.google.com
Does anyone know if this file is compatible with my system? Will it still attempt to install if it's not compatible, or will it detect this and cancel installation? This is my first time installing an update so not sure.Прошивка Cupra – Google Drive
drive.google.com
Did you do OTA update ?i successfully updated my nov 2020 leon with h56 and 1969, it detects if the version is compatible and it lasts about 35-40min, all work flawlessly. Thank you!!!
No, I did it via USB with the files shared yesterday. 0 issues. It was my first update via USB and all perfect.Did you do OTA update ?
H61 here.Does anyone know if this file is compatible with my system? Will it still attempt to install if it's not compatible, or will it detect this and cancel installation? This is my first time installing an update so not sure.
No problem, the system verifies your Hardware and it applies only the necessary files.H61 here. View attachment 49925
All in root folder, no new folders created and formated with fat32 (32gb) with USB as the device name, sorry for my english any doubt please tell meAwesome, I’ll give it a shot tomorrow. How did you format your USB? Exfat/ FAT32? And did you place the files in the root of the USB, or did you have to create a folder? I think I saw it needs to be in a ‘CUPRA’ folder?
All in root folder, no new folders created and formated with fat32 (32gb) with USB as the device name, sorry for my english any doubt please tell me![]()
I did it with the engine running, 1.5 Petrol with no hibridView attachment 49926
Nice, thanks for confirming. USB ready and it seems like the car is happy to accept it. 'Y' for most, I assume the 'D' doesn't need to update.
I have a petrol only vehicle, not a hybrid, so should I update with the car running and in park so I don't drain the 12v battery? Anyone have any advice?
