Jenk's mk4 Ibiza Soot machine! (Time to bid farewell)
Feb 20, 2005
3,476
Telford ay it...
Took the mk4 to Curborough again as my mk2 failed its MOT, had a cracking day and I think I took 0.3 secs of my time. It needs some love now though, I don't think the rear cailipers are up to much......disks are not cleaning up and there was hardly any heat in them, plus the brakes feel cack. I'll trawl some threads but hopefully its just a case of cleaning the slide pins? Fresh fluid is deffinatly needed too!
Feb 20, 2005
3,476
Telford ay it...
Sorted the rear brakes I think, pads where fused to the carriers. Slide pins are moving nice and the piston wound back in easy. Just to see if they clean up now :)
Feb 20, 2005
3,476
Telford ay it...
Cracking action shot, not sure who took it but credit to them :D
seat-sloany
the mark4 is lovely :O i had a yellow 1.2s for my first motor and it picked up all the dirt off the road :L
seat-sloany
aye. i used to have a seat toledo 1.9 tdi 110bhp that was a beast!
Feb 20, 2005
3,476
Telford ay it...
Diesel and -10 do not mix well, all the way to work the filthy one was in what appeared to be limp mode (no CEL though). Just took if for a short ride and it seems fine again :confused:
Feb 20, 2005
3,476
Telford ay it...
Im pretty sure diesel comes with the necessary additives for freezing? I'll Vagcom it when I get home, im not sure if it will tell me anything though as there was no engine light.
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
mine took forever to start this morn luke, it was -12 here, nice puff of black smoke, but then was fine (well I couldn't get out my Cul-De-Sac though, as it's a big incline) :(
PS needs stance :p hahaah
Feb 20, 2005
3,476
Telford ay it...
Its running all sound now, wondering if I turned the key a bit to soon.....not allowing the glow plugs long enough so it had a pap :shrug:
Its got stance on the front Suj, been plowing the snow :happy:
Aug 19, 2007
1,149
East Yorkshire
Mines been doing the same below certain temperatures. Got a feeling there may be a safegaurd programmed into the ECU, which in extreme cases (this case running lean) sends the car into limp mode to protect the engine from damage. Only thing I can think of, as it goes as the temperature goes back to around -5deg.
Feb 20, 2005
3,476
Telford ay it...
Ahh would make sence, I had been searching the forums to see if anyone else had the same thing crop up, but nothing. With how bad the roads where that day it helped not having the boost kicking in.
Feb 20, 2005
3,476
Telford ay it...
Soft question, hence why its on my readers ride thread :) .....these 312 front disks, I'm ordering S3 items yeah? New brakes all round coming, along with a service before MOT time. Few other bits to sort too.......lots of moneys to spend!
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
I'd have thought they should be fine. I ordered Audi TT 1.8t discs. The 1.8t TT's have 312s, but the 3.2 V6 have the same 330mm brakes as on the Mk4 Golf R32. So if you wanna be 100% sure, 1.8t Audi TT will do you no wrong :)
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,992
Newcastle
Thought the TT 225 had larger discs? The last 312mm discs I bougt were for a 180 TT..
Also a mk1 LC 180 has 312mm discs :)
