New hoops on trial
Ignoor the weeds.....
Cheers :)
Need new spigot rings (0.5mm out) and im unsure if the standard bolts have the correct taper on them for these wheels? ET seems near enough bang on, well chuffed with them :D
Cheers :)
that's not too bad then mate!
how much did you win them for in the end?
Deffo tapered bolts.
Cheers Andy, riffled through my bits and I just seem to have odd ones.
Im struggling to think of a place that would sell them without trying to rob me blind. Found the spigots on the bay for £11 delivered.
On a non wheel not, just found pin holes in the first bend of my exhaust rear section. That was put on new when I had it last. Took it off to see if I can bodge it, it was like a puzzle getting it over the rear beam.
Spigot rings ordered and a nice new pukka low entry jack is on its way :)
Any ideas on the wheel bolt length peoples? Need to get those ordered.
Went for a sealey 3 ton yankee low entry jobbie, looks the biz. Read to many bad things about ally jacks, flexing under load and even breaking. Seems you have to spend mega for a good lightweight jack. I read costco put them up aswell to the £90 mark?
New tool! :D
Pushed on wednesday and removed the front bumper and wing, bumper fittings where buggered so took ages to remove. Ended up cracking the drill out and breaking a few drill bits........all ready for prepping and welding the strut now.
For now yeah, still cant unfree them though :censored: The bodies are spotless (stainless) but the main ring on the front near side wont shift.
It needs rasing as the current height is hardly optimal for handling purposes, wishbones are to be near as parrallel to the ground as I can get them. No more low and slow for the purple one :)
