yea danny would cause a problem as maf would be reading the air coming in but if engine was getting more air wouldent be running right i.e incorrect boost :).
That what I was thinking Dave but wanted better logs to check. ECU retarding boost but if so then why not one flat boost level like limp mode.
Danny you may get a higher boost spike in a higher gear if doing say motorway speed then go wot as ther is already alot of flow.
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Scanned Danny's car today as it was in limp mode and these are the fault codes that came up, we removed the sai fully after scanning with the blanking plate, so that fault code shouldn't come back again.
We know the first fault code is for the lambda, which Danny is sorting out at the min
But were wondering what the bottom code is, as that has only appeared when we scanned it tonight, anyone got any ideas what could be causing it?
Just got off the phone with curzon and that code does point towards the 02sensor (lambda)
So am gonna get one asap...
We did a maf runs and it pulled 170+ G/s so its working fine...Plus Since i changed the vac pipes that Devastion Code(boost Leak) hasnt come back...
I'd agree it's the lambda sensor.
17536/P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean
Possible Symptoms
* Malfunction Indicator Light (MIL) active
Possible Causes
* Mass Air Flow (MAF) Sensor faulty
* Oxygen Sensor Control faulty
o Oxygen Sensor(s) faulty
* Fuel Injector(s) faulty
Possible Solutions
* Check Mass Air Flow (MAF) Sensor
* Check Oxygen Sensor Control
o Check Oxygen Sensor(s)
* Check Fuel Injector(s)
what i thought and as allready has this code
would sugest lambda is causing it to not fuel correctly now.
not sure if be causing your boost issue but need to get it done anyway mate so its cleared off then can look at everything else. 1 at a time mate :)
Told you when you first posted the code up! Pre cat lambda needs changing. If once its changed its not ok then it might be your decat. You may find that sai code still comes up as som people that remove it still get it.
Right danny got a new lambda sensor on and now hes got no fault codes at all but still driving the same maybe abit better not alot.
did a log of 115 and seems to be meeting requested most of the time apart from when its asking for max boost it only give 14 psi ask's for 17psi what you lot think?
Code:
1400	65.4	990	1090
1440	66.2	990	1100
1480	63.9	990	1110
1560	91	1500	1140
1640	96.2	1550	1220
1720	100.8	1620	1280
1760	103	1690	1340
1880	107.5	1820	1400
1960	114.3	1950	1470
2080	124.8	1980	1570
2200	147.4	1990	1770
2360	169.9	2000	2020
2480	175.2	2010	2200
2680	172.9	2030	2190
2800	166.2	2030	2130
2960	160.2	2020	2000
3120	165.4	2000	1980
3280	166.9	1960	1980
3440	165.4	1930	1960
3560	160.9	1890	1940
3720	158.6	1880	1900
3840	159.4	1850	1890
4000	157.9	1820	1870
4120	157.1	1830	1850
4240	158.6	1810	1850
4360	157.1	1780	1830
4480	157.1	1760	1800
4600	154.9	1740	1780
4720	157.1	1730	1780
4840	157.9	1720	1760
4960	157.1	1710	1750
5120	158.6	1710	1740
5200	159.4	1740	1740
5360	158.6	1760	1750
5480	158.6	1790	1770
5600	160.9	1810	1790
5640	163.2	1840	1800
5840	164.7	1860	1860
5920	165.4	1850	1880
6000	163.2	1820	1850
6120	161.7	1780	1840
6200	158.6	1750	1820
6280	154.1	1570	1790
6360	146.6	1600	1710
o and only reason he ended it at 6300 was he was going round a corner and it **** me up as was going fast lol. will do some proper logs some time on a straight road.
Thanks Chris..
If its my jabbasport map...not Running right on a k03s as it worked so well on a k03 which it was mapped for no?
if its defo my map Ive got a slot on saturday @ motech perfromance for a custom map to put all my mods together...
