shaker
just wondering if anyone could tell me what maf g/s should be at idle
i have just checked mine and it reads 2.9g/s and thought it might be a bit low
ill try that over the weekend just on the learning curve with vag com
but keep getting fault code p0411 and cant seem to find any hose leaks so im just trying o rule out other things
yes checked that couldnt find anything clear the code and it runs fine for about a week then seems to have a loss of power through low revs and stutters through low gear changes
Look in the VAG-COM forum section of this website and you'll find all the info you need on where and how to buy VAG-COM and the necessary cables.
anyone else got any suggestions what might be causing this
stuck!
just found a pipe tucked down the side of the engine apparently it should fit onto the air box would this make any difference as when i bought the car it only had the aftermarket filter so have nothing to plug it into
yes it has a small filter on but thought that might be whats throwing up the fault and causing the problems
