MK3 Ibiza Cupra* K03s Jabbasport* Moving on....
Apr 15, 2009
2,188
Midlands
both lambdas fitted in the same location in the narrow section of the pipe?
not where I would have put it..
Couldnt see anywhere else to put it without fouling anything
I basically used RobbieC pictures for inspiration as he has his in the same place
Where would you have put it, nearer the top?
Apr 15, 2009
2,188
Midlands
Thread on downpipe is sorted, just had it cleaned up etc
Sensor and blank screw in perfectly now
Header tank arrived
Started to wrap the downpipe but gave up, the stainless ties are absolutely crap and the dont hold the wrap very well so struggled to get it tight.
Might just put some on the gear lines which are melting and leave it at that
Apr 15, 2009
2,188
Midlands
cant you just use a jubilee clip top and bottom mate? they should hold well
Use jubilees, or you're using the metal tie wraps incorrectly, I found the eBay ones that came with the wrap are really good, you kind of tigthen them and pull them back on themselves?
Got a couple of Jubilees spare and they actually work alot better imo
Bit itchy now though, should have wore gloves i think :lol:
good work mate should be sorted soon then ?
Thanks mate, this weekend it will be all done :D
Apr 15, 2009
2,188
Midlands
Update Time!
Everything has been refitted today, downpipe, turbo etc no leaks or anything so all good there.
Wideband is fitted and working
Just got to fit the rest of the exhaust tomorrow and its back!
Ill get some pics up sometime over the weekend
And new wound courtesy of this car lol, sliced a huge chunk out of my thumb this time and now have a square ended thumb!
Changed my gauge plans again too, getting a cupra r holder now to house the wideband etc
Apr 15, 2009
2,188
Midlands
Back on the road now
Managed to get the Blueflame to sit alot better this time too :D
Fuel pump was certainly the cause of my lean running
Wideband is reading .84 at WOT in 4th gear (Lambda reading) which is better than the 1.02 reading on the rr day before the fuel pump was fitted
AFR reading are in the 11's too
Apr 15, 2009
2,188
Midlands
Finally mounted my wideband properly, i was against using the cupra r holder because i like to use the centre console for storage etc
After finally deciding to keep the heater aswell i was running out of option so i came up with this
Took one dash mount pod
Mounted it upside down at the front of the centre storage compartment.
I actually love the positioning as the holder is adjustable left and right, up and down etc so i can tilt it to a much better position than the cupra r holder :D
Looks tidy too imo
Passenger side view
Or adjusted up to get a better view from drivers seat
Just need to tuck the wiring away and job done :D
Jul 4, 2010
2,170
Cambs
Now thats dedication!
might have to steal your guage holder idea becuase I am gunna ditch the centre console and realised I have nowhere to put the cupra r holder lol
Apr 15, 2009
2,188
Midlands
Theres enough space for at least 3 down there, i mounted mine a bit more central as its the only gauge ill be using down there.
Best this of all is you can adjust the pods to sit in whatever position you want which is another reason i did it instead of the cupra r holder.
Do it :D
Jul 4, 2010
2,170
Cambs
Yeh I was hoping i could fit 3, thinking EGT, Wideband & WMI
+ my boost and oil temp guages it will be like a rave in there haha
Got to love a gauge though!
Apr 15, 2009
2,188
Midlands
Lol they do look great at night when they are all lit up, 3 will definately fit, have you got a nomad pillar pod aswell?
I like that actually :), I need to get some pictures of my Zeitronix system install.
Berg, did the studs/ nuts fit?
Definately get some pics up mate ;)
Yer the studs and nuts were correct, thanks again for those :D
