MOT tomo... quick question
attila_tdi
384
Hampshire
I have MOT booked tomo... just wanted to check one thing:
My NS front light does not adjust (angle) when I move the adjuster on the dash. The OS light moves up and down, but the other stays put.
Is this an MOT failure?
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
IF the beam is in the right place or can be adjusted at the headlight its self its fine just the electric motor has failed and not adjusting from inside the car
they cant fail that just if the beam is out and cant be readjusted
attila_tdi
384
Hampshire
so i guess you can adjust the beam from the outside of the car? (i.e. traditional method) is that correct?
Sorry to sound dumb
attila_tdi
384
Hampshire
Well I'll keep you guys posted (thanks for the heads up so far)...
Watch this space as I predict I could be breaking some records with the most expensive MOT repairs of all time...
CV gaiter worn
Front lower suspension arm bush worn
4 new tyres (low profile)
And I try to keep it serviced consistently!
