Hi there mate,
I am pretty new to the LCR fan club and I have recently bought a standard example myself about 4 weeks ago now.
I have been reading through all your posts and I like the mod's you have done to your LCR.
I reckon in a few weeks when I have a bit of spare money I will embark on some mod’s myself. Maybe, FMIC, Sports cat and exhaust, Remap, Etc.
I was just wondering if you could explain to me what they actually mean by hybriding a turbo and what sort of HP gains do you get from it and is it a cheaper way of getting the LCR's power nearer to 300HP than a BT conversion????
Also you mention 'logging' quite a lot. How do you do the logging and do you have the details on what I could do to do the same on my LCR????
Cheers mate.
Thanks for the comments Jabre.
When they hybrid a turbo they remove all of the internals and uprate these installing a higher flowing compressor wheel, trimmed turbine wheel, high performance bearings and in some cases a slightly reworked housing which allows for slightly higher boost and, I believe, quicker spool up.
TBH 300bhp should be achieveable, i think, on a standard K04 as I currently run Custom Code stage 1 and on my best logging session made approx 280bhp so stage 2 I reckon would be just shy of 300bhp.
Finally logging is done via VAG-COM, a VAG diagnostic PC application, and you measure certain attributes and the application then records these and presents them in a spreadsheet format when complete. From these logs you can tell, for example, if you car is over boosting/under boosting, over fueling/under fueling so on and so forth.
Hope this helps.
