Oil Catch Tank..Why you need one.
jamiebennett81
no, that was for the TIP mate,
as said befor i think ill run mine same as looneys.
yes, so different setup to mine, as I have the PCV valve on, so I am guessing will need to do something else to remove the PCV valve......:(
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
you can keep the pcv valve there, its a one way valve, and redirect thge fume hoses to the catch tank, OR remove the pcv completely and plumb the fume hoses, both work, and dont throw codes.
jamiebennett81
thanks Bill
when you say plumb the fume hoses, what do you mean exactly?
going on Nev's question, I presume if you are not running a pipe from the PCV valve to the catch can, one pipe goes from top of the block into the catch can (no T piece used this time) and a return pipe goes from the catch can to the bottom of the block
so now the PCV pipe has been taken out of the catch can equation, where does the pipe from the PCV valve go?:confused:
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
thanks Bill
the catch can. the vacuum side would be blocked off at the manifold if you removed it.
free venting catch cans smell nasty
(unless you run motul 300V nice smelling oil :D )
jamiebennett81
so best leave it then if it is going to vent to the air.....as I dont have nice smelling oil:)
I will leave the PCV in and run the setup as demonstrated on this thread
Loony R
Quattro ist fur sissies
Nov 23, 2007
244
Rossendale
Here's my "home made" tank vented to air, only notice smell if she's had a kickin and I'm sat at traffic or slow movin.
jamiebennett81
well I went out to do the catch can today....getting there slowly. Made up the mounting brackets
however, I have the 19mm Forge flexi hosing to come off the rocker cover (this works fine)
I also have some some 16mm Forge flexi hosing which is also correct, to go onto the Catch can "15mm" fitting
however, when placing the 16mm hosing over the catch can fittings, the hosing is way too big!!
I have just measured the catch can fittings and they are only coming in at about 12/13mm and are way to small for the 16mm hosing
any ideas on this?
I am just about to email toyosports directly to see what they see....not impressed!
jamiebennett81
Jamie, did you get any pipe or tube with the catch tank? i did, and the 16mm fits over it a treat and then just do the jubilee clips up works a treat.. :D
yes I got some crappy awful looking tubing, but the end connectors are not 15mm....hence the 16mm Forge hosing is way too big
were your end connectors 15mm then?
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
not sure what they are but with the pipe that came with it on, and cut to the length of the connectors it makes it about right so the 16mm pipe fits over it a treat
jamiebennett81
well I found this, reducer from 19mm to 12mm, which will do the job
http://www.aquaessentials.co.uk/index.php?main_page=product_info&products_id=1368
now just ordering some 13mm hosing from merlin motorsport, 1mm difference will be fine and this is the only semi decent looking flexi hosing I can find of this size which will match the 19mm flexi hosing I have
vee_dub_modder
Volkswagen racing tech-pt
Feb 19, 2008
406
Midlands
nice on all accounts... loving the goodridge idea :p I mounted mine off the old airbox mount on the n/s/f turret. looks sweek as... just need some nicer pipework pefore i publish i picy lol god work guys!
turbin
About six months ago i fitted the oil catch tank and today i thought i would have a look.
:-o what is all that crud, if i had not got a catch tank this would be in the pipes and intercoolers and its only after six months. All i can say is look at the pic's and go and buy one.
-what oil do you use?
