Owens development turbo project Octavia vRS.....
steevie wonder
The silver bullet
Apr 20, 2007
60
Midlands
Not a Seat, but near as dam the same thing!
Gone for the Owens beast for my Octy vRS, currently running the vf34 IHI which is nice and smooth, but i'm having (in addition to my current setup-see sig) the following spec fitted:
  • AGU large port head - ported and flowed
  • Supertech inconel/nitrade valves
  • JE 82.5mm pistons (9:1 CR)
  • Scat rods (20mm pins)
  • Baffled sump
  • Snow performance methonal injection system
  • 880cc (I think) injectors
  • Bosch inline fuel pump (additional pump)
Jabba will be doing a photo diary of the work, so i'll be posting that once it all starts.
Anyone with any experience with this set up please comment. It'll be either the stage 2 or 3 set up, not decided yet, but i'm hoping for mid 400's for torque and bhp.
Steve:)
G12MO X
84
You will look it , Running mine for 2 months and it is outstanding:D
Looking forward to Mike doing 2L bore and stroke then it will be finished
BTW I have a Pro Alloy intercooler spec'd by Mike and it is unreal, Temps are now silly low .
steevie wonder
The silver bullet
Apr 20, 2007
60
Midlands
What size fmic is that? Mine is already quite big (ProAlloy), but the methanol should help keep intake temp's down.
What pistons do you use at present? OEM bore 81mm? 8.9:1 CR?
What is lag like?
Cheers in advance,
Steve
ryan_s3
1,270
gizmo is your car still stripped out etc?
Have you ever done any logging with a performance box?
G12MO X
84
Below is my spec, My compression is meant to be 8.5-1 but Mike thinks it is lower(quite a bit) don't know where it has gone wrong(jabba did not fit rods or pistons) So next job is to correct it and upgrade at the same time:D
going for bore and stroke to 2L (just under), Eurospec crank and 82.5 @ 8.8 comp pistons
, baffled sump, S4 TB and Jabba spec cams (if ready)
Can't wait :D:D
1.8T (BAM with AGU large port Head )
Owen’s IHI/Garrett Ball bearing turbo
HF Cast Jabba Sport polished and coated exhaust manifold
JE 81mm - 8.5-1 Lower comp forged pistons
SCAT H-Section Con Rods
Supertech Inconal Intake and exhaust valves
APR large port inlet manifold
R32 throttle body
FORGE 007 DV relocated
ProAlloy front mount intercooler with 70mm Turbo to Inlet manafold hardpipes
BLUEFLAME Exhaust
Jabba Sport custom Intake pipe
2 bar Boost Sensor
550CC Genesis injectors
BOSCH 044 inline fuel pump
Jabba Sport 3’ down-pipe
Jabba Sport custom sports Catalytic converter
Standard airbox
SPEC Stage 3-PLUS Clutch kit
SPEC 5 KG Steel single mass flywheel
N249 Removed
N75 Standard
HALDEX Performance controller
ryan_s3
1,270
caney do you have the performance box?
It would be interesting to see what sort of 30-130 times you get.
caney
600
no not yet mate,looking to book a couple of hours at brunters when the weather picks up to do some times and top speed runs,fancy coming along?
BenS1
3,459
West Sussex, England
Can't wait :D:D
R32 throttle body
BLUEFLAME Exhaust
2 bar Boost Sensor
Standard airbox
N249 Removed
N75 Standard
I'm looking at the Owens turbo too for my Ibiza (Currently 360bhp IHI VF34 P20).
Which version of the turbo have you gone for? The one described as "400+bhp" or the one described as "475bhp"?
I see from your sig that you're getting 420bhp... is that from the above spec, or have you since gone aheaqd with the 2 litre conversion and/or other mods?
Ben
G12MO X
84
Ben
Jabba do 3 versions, mine is the middle one (450 ish), My car made 420 but my mate has the same turbo and set (almost identical) and his made 450, My engine droped a spectech valve and is currently being rebuilt by Jabba :D 2L (82.5 bore and Eurospec 12.5 KG billet crank , ported polished and water meth , let see what it makes:D
BenS1
3,459
Interesting, I didn't know there were 3 versions. The Jabba site lists one and the Owens site lists 2. If there are 3 then that's perfect, I'll go for the middle one. :)
Sorry to hear about the valve problem. Any idea why it happened (I've got some supertech valves waiting to go in)?
I'm planning on going 1.9 litre (83mm pistons instead of 82.5) and possibly the 2 litre crank. I've got a large port AGU head waiting to go on too which I've get flowed. Already got Aquamist water/meth injection.
I see you're running 1.7bar boost. Any particular reason that 1.7 bar was chosen? I'd heard that these turbos were rated as being reliable at 2.1bar.... I'm guessing you kept it a bit lower for heat reasons?
Ben
BenS1
3,459
Ok thanks. I have an EGT guage but Jabba couldn't connect it up when you did my IHI conversion... may have to revisit that.
Whats a safe limit for EGTs then... no point having an EGT gauge and not actually knowing what to look out for.
Ben
G12MO X
84
Ben
It is running 1.7 to red line but peaks at 2.1bar, I have gone 82.5 as i have been told this is the safest bet by mike.
BenS1
3,459
Ok makes sense.
Do you have a power graph from Jabbas rolling road. I'd love to compare it to my IHI one so that I can see how much later the boost comes in etc.
Here's mine:
