Neuspeed kit uses boxster 2.7 fronts with the connecting pipes bleed nipples reversed to account for the lead/lag.
had a neuspeed kit and its helicoiled aluminium carriers uses M10 bolts instead of M12 and very lightweight, possibly too lightweight. Didnt fit it.
Word of warning some boxster calipers were originally designed for a 20mm disc and wont fit a 25mm 312 disc, better off buying rears of a 996 as opposed to fronts of a Boxster unless they are new of course and you have the correct part number generally 2.7 boxsters had the correct 24mm discs at the fronts whose calipers will fit the 312
in other words BOXSTER REARS (ALL YEARS [EXCEPT 3.2 they're ok]) dont work on the 312, boxster part numbers begin 986.xxx.xxx.xx and when covered in powder coat/enamel paint the 8 in 986 can look like a 9 - result misery when you get home
