Dan, like you say mate can't do any harm doing another compression test, but it soundn't make much diffence if the engine is hot or cold.
Would be interesting to see if there is any difference though mate, might help you with the fault finding.
From what you say about the vvt it sounds very timing related to me, pop the rocker cover gasket and check the cam chain there should be 16 rollers countable on the top run of the chain (starting from and including the one above the arrow on the bearing caps and including the last one above the arrow)
Heres a linky incase i never explained it well - http://www.seatcupra.net/forums/showthread.php?t=240036
Let us all know how you get on matey.
.................................Sorry.
