thats great thank you. if it is dead i will be giving you a call for a new forge one.
if forge is the best way to go?
cheers
cheers
Nobody seems to have answered the question of how can you tell the difference.
If you look at the dump valve there is a little pipe on the top which is just vacuum. there is usually to other ports on them, one on the bottom and one on the side. one of them will be into the pipe coming from your air filter (TIP), if the other is open or has a cone on it then it is venting to atmosphere, if there is a pipe on it then it is recirculating, if it actually has 3 ports one in the TIP, one with a cone and one with a pipe then you probably have a split valve whereby it recircs half and vents half.
the other option is to post a pic of it lol
