It aint expensive.. cos its already thereSim said:Yes you can, of course! Though it is expensive (and too big) just to let it catching dust there IMHO.
ibizacupra said:It aint expensive.. cos its already there![]()
Sim said:Hehe yes, you're right. Though if you need such a valve for other purposes (it's really an allround solendoid, selecting the path/route of air electronically) then it's there. You also would have to close/clog all of the unused ports preventing dirt getting into it and that would look awful i guess. Resistors can be more easily hidden somewhere.
mechanically.. disconnected. so no CEL'sSim said:You've just disconnected it electrically or mechanically?
If only electrically, you'll have the CEL and you'll have the ~2mm restriction (id of N249 valve) to DV.
If mechanically (and left it electrically connected), that's ok, but don't know if it can get clogged with dirt (over time) and may fail to work once plugged in again. I may be too paranoid though![]()
Sim said:WOW! Nice box. The 33.33 Ohms may work, though a bit off spec. Inform us if ECU is happy with it or not!
Shock_Xe said:I started to do this today, made the Resistore board, using 3x 10w 100r as this was all they had in stock which was close to spec. Will try it, Coulednt finish it as samco tubing didnt arrive, will take pics when finished
Bought a cool bupane solder/heat knife/blow torch, awesome bit of kit!!!
Pic of my 'Box' black Metal, hopefully gonna hide it up by the pollen filter somewhere, plenty of room for products to breath
LCR mat said:so thats what you were up to instead of meeting up eith me to do some logs
cuprabaz said:what a nice guy!
Glenn said:Could this be used as part of a knock reduction strategy?
The G60 bleeds boost off via the ISV (in certain conditions) when knock is not reduced via retarded timing.
I think it would be better to know exactly why this change has been implemented on later 1.8Ts before playing around with it? There may be reasons that go beyond it's apparent function? The engine designers know more than we do - new product features are not just added 'for a laugh'.
